Wind River (2017) - Audio Issue
AngryVirginian
Post by AngryVirginian »
I am having an audio issue with Wind River (2017) blu-ray ripped with 1.15.2. There is no audio at all during the first two minutes of the movie played through Plex. This happens in both DTS-HD MA and the underlying DTS tracks. The disc played fine through the Xbox One. Below is the log.
AV sync issue in stream 1 at 0:00:15.056 with duration of 105.071s : encountered overlapping frame, audio skew is +105.071s
AV sync issue in stream 1 at 0:00:29.237 : audio changes from 16bps to 24bps, you won't be able to convert this track to any other format later, please use a conversion profile with audio transcoding
AV sync issue in stream 1 at 0:00:29.237 with duration of 1008.5ms : encountered overlapping frame, audio skew is +90.89s
AV sync issue in stream 2 at 0:00:15.056 with duration of 105.071s : encountered overlapping frame, audio skew is +105.071s
AV sync issue in stream 2 at 0:00:29.237 with duration of 1008.5ms : encountered overlapping frame, audio skew is +90.89s
AV sync issue in stream 1,2 at 0:02:00.128 with duration of 106.08s : 9945 frame(s) dropped to reduce audio skew to -0.208ms
Seems like a big chunk of the fames got dropped. Any hint on how to fix this is appreciated. Thanks.
lmm5247
Re: Wind River (2017) - Audio Issue
Post by lmm5247 »
AngryVirginian wrote:
Thu Aug 13, 2020 9:04 pm
Hey, what did you end up doing with this? I'm having the same issue, first two minutes with no audio on this stand-alone disc when ripped from MakeMKV.
Saving 1 titles into directory /home/XXXXX/Videos/Wind River
AV sync issue in stream 4 at 0:00:00 : Forced subtitles track #4 turned out to be empty and was removed from output file
1 titles saved
I am going to try this copy, but it's all 3 films on one disc, so they're each significantly smaller than the stand-alone copy.
