Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
Re: Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
marcbi91 wrote: Thu Nov 20, 2025 2:17 pm Hello,
I have the same issue with the BDR-XD07UHD. None of my BR UHD 4K are readable with MakeMKV.
Can you help me ?
Informations lecteur
Nom du lecteur SE : \Device\CdRom0
Profil actuel : BD-ROM
Fabricant : PIONEER
Produit : BD-RW BDR-XD07U
Révision : 1.06
Numéro de série : ADDL002120WL
Date micrologiciel : 2024-10-09
Marqueurs d'encryptage bus : 13
Version AACS la plus haute : 76
Drive platform: Pioneer RS8D31
Firmware version: ID05
Aucun disque
Merci :)
You need to update the SDF.bin by allowing Makemkv access to the Internet. Then restart your PC.
viewtopic.php?f=19&t=39869
marcbi91
Post by marcbi91 »
Coopervid wrote: Thu Nov 20, 2025 3:35 pm
Can you help me ?
Fabricant : PIONEER
Révision : 1.06
Aucun disque
Merci :)
Thank Coopervid for your answer.
I downloaded the SDF.BIN but I do not understand where I have to copy it and what actions I have to do to include it.
In the thread, they talk about an _private_data.TAR? I don't have this file.
I'm working on Windows.
Can you assist me ?
The SDF.bin(s) are in a compressed file _private_data.tar at the location C:/users/YOURUSERNAME/.Makemkv. If you find it you can open it with 7-zip and it should contain sdf_0000009c.bin as the last file item. If not, copy your downloaded SDF.bin to that location but if you have Internet access enabled for Makemkv it downloads the .tar file automatically. Make sure your firewall settings do not block the Internet access.
Check and report back.
marcbi91
Post by marcbi91 »
Coopervid wrote: Fri Nov 21, 2025 10:52 am The SDF.bin(s) are in a compressed file _private_data.tar at the location C:/users/YOURUSERNAME/.Makemkv. If you find it you can open it with 7-zip and it should contain sdf_0000009c.bin as the last file item. If not, copy your downloaded SDF.bin to that location but if you have Internet access enabled for Makemkv it downloads the .tar file automatically. Make sure your firewall settings do not block the Internet access.
Thanks for sharing.
I deleted the _private_data.tar on my folder.
I stopped MakeMKV, I unplugged the USB drive. I plug again the USB drive and run MakeMKV again
MakeMKV downloads the last version. In this new TAR, the last SDF is xxxx09c.BIN as expected.
However, I'm still unable to read the UltraHD BluRay Disk (I tested several discs) :
'Erreur SCSI - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT'
Here is the current settings :
Nom du lecteur SE : \Device\CdRom1
Fabricant : PIONEER
Révision : 1.06
Version AACS la plus haute : 61
marcbi91 wrote: Fri Nov 21, 2025 12:22 pm
Thanks for sharing.
Fabricant : PIONEER
Révision : 1.06
Did the log window say a firmware dump was generated? Check the MakeMKV data directory and if the firmware dump is there, email it to support@makemkv.com so Mike can add it to enable libredrive.
marcbi91
Post by marcbi91 »
MartyMcNuts wrote: Sat Nov 22, 2025 7:19 am
Thanks for sharing.
Fabricant : PIONEER
Révision : 1.06
Yes. I sent the dump to support@makemkv.com
NCC906
Post by NCC906 »
@coopervid: can you please help me get UHD discs working like you have the others in this thread?
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.02
Serial number: [redacted]
Firmware date: 2019-09-05
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: RS8D30
Firmware version: 1.02
NCC906 wrote: Mon Dec 15, 2025 4:46 pm @coopervid: can you please help me get UHD discs working like you have the others in this thread?
OS device name: G:
Revision: 1.02
PM sent.
marianlena
Post by marianlena »
@coopervid: Hi, can you help me get UHD discs working? Thanks.
OS device name: G:
Current profile: BD-R SRM
Revision: 1.01
Serial number: xxxxx
Firmware date: 2018-12-03
Drive platform: Pioneer RS8D30
Firmware version: ID36
marianlena wrote: Wed Dec 17, 2025 3:53 pm @coopervid: Hi, can you help me get UHD discs working? Thanks.
OS device name: G:
Revision: 1.01
PM sent.
TzehPesh
Post by TzehPesh »
I would be very interested and appreciative of any info regarding the below drive. Thanks in advance!
OS device name: B:
Revision: 1.03
Serial number: xxxxxxxxxxxx
Firmware date: 2020-08-20
Firmware version: 1.03
TzehPesh wrote: Wed Dec 31, 2025 11:51 pm I would be very interested and appreciative of any info regarding the below drive. Thanks in advance!
OS device name: B:
Revision: 1.03
PM sent.
threeballspin
Post by threeballspin »
Product: BD-RW BDR-XD07U
Revision: 1.03
Serial number: XXXXXXXXXXXX
Drive platform: RS8D31
Firmware version: 1.03/ID05
threeballspin wrote: Wed Jan 07, 2026 9:56 pm Drive Information
Revision: 1.03
Why are you posting this? Your drive is already UHD capable. Nothing to do. Just insert a UHD disc and start ripping.
threeballspin
MartyMcNuts wrote: Wed Jan 07, 2026 11:52 pm Why are you posting this? Your drive is already UHD capable. Nothing to do. Just insert a UHD disc and start ripping.
Sorry. Bit of a noob. I tried to rip a disk but it didn't work. So I thought I needed to do something to the drive.
