WH16NS40 But I think I'm in Trouble
MuzzyKlips
Post by MuzzyKlips »
I bought an LG WH16NS40 off Ebay and MakeMKV shows information below. It appears I can watch and rip regular Blu Ray Discs, but not 4K UHD ones. Is there any fix?
Thanks,
Muzzy
OS device name: F:
Product: BD-RE WH16NS40
Revision: 1.01
Serial number: K94DAP85650
Firmware date: 2113-12-06 16:58
Highest AACS version: 76
Drive platform: MT1939
Firmware version: 1.01
BD raw metadata read: Partial
Re: WH16NS40 But I think I'm in Trouble
no to old
xwmkf
Post by xwmkf »
MuzzyKlips wrote: Fri Nov 21, 2025 12:44 am I bought an LG WH16NS40 off Ebay and MakeMKV shows information below. It appears I can watch and rip regular Blu Ray Discs, but not 4K UHD ones. Is there any fix?
The "MT1939" drive platform means it can't be flashed to support UHD.
MuzzyKlips
Weird thing is it's brand new.
MuzzyKlips
It as manufactured in February 2024!
MuzzyKlips wrote: Fri Nov 21, 2025 4:01 am It as manufactured in February 2024!
Nope. You got one of those fakes which is an old drive (usually from 2013, which yours is as the firmware on it is from 2013) with the older MT1939 drive platform. All they do is slap a new label on them!
xwmkf
Post by xwmkf »
I've learned that we can't trust the labels from ebay (esp china sellers, but in my case also a US seller). Those drives (WH16NS40 platform 1939, SVC code NS40) haven't been made since 2015 or so, and so a label that says eg in my case "2024" ends up being a fake label.
skyfox2003
Post by skyfox2003 »
I would like to note that I have a MT1939 like this that I have been using for years. Not necessarily on UHD's. But works great for typical Blu-rays. So its not completely Junk.
