SDF update November 2025
Re: SDF update November 2025
Coopervid wrote:
Thu Nov 20, 2025 10:16 pm
Are you sure? 8801 indicates a S11 /211 drive.
i will have to check i have not powered mine on yet and probably wont for some time have a lot of xd08 to do
i assumed its the same hw as the x13 series as its in the same case and similar release date
Billycar11 wrote:
Thu Nov 20, 2025 10:26 pm
X13s are 94xx. 8801 seems to be a S11 /211.
Coopervid wrote:
Thu Nov 20, 2025 10:35 pm
does seem to be the case
viewtopic.php?t=27378&start=1380#p171443
Then should be sending it to Mike.
