Pioneer bdr 209 and Pioneer bdr 209m
Re: Pioneer bdr 209 and Pioneer bdr 209m
#121 Post by Coopervid » Wed Nov 12, 2025 4:12 pm
Treguard wrote: Wed Nov 12, 2025 12:31 pm Hi
Please could you tell me if it's possible with mine so that I can play UHD discs on it?
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.20
Serial number: NFDL015878WL
Firmware date: 2014-04-08
Bus encryption flags: 13
Highest AACS version: 42
Drive platform: RS8600
Firmware version: 1.20/ID60
The drive is still working...of a fashion. You have to press the eject button quite a few times to get the door to open.
PM sent.
GavinC
#122 Post by GavinC » Tue Nov 18, 2025 12:08 am
OS device name: E:
Revision: 1.10
Serial number:
Firmware date: 2013-09-10
Firmware version: 1.10/ID60
Many thanks,
Gavin
#123 Post by Coopervid » Tue Nov 18, 2025 10:00 am
GavinC wrote: Tue Nov 18, 2025 12:08 am Hi,
OS device name: E:
Revision: 1.10
Serial number:
Many thanks,
Gavin
PM sent.
T0biasCZe
#124 Post by T0biasCZe » Tue Nov 18, 2025 3:35 pm
Hi, could you please tell me if my BDR-209M is able to be flashed to be UHD capable?
OS device name: N:
Revision: 1.34
Serial number: QDDL0...
Firmware date: 2016-04-25
Firmware version: 1.34/ID60
Thank you
#125 Post by Coopervid » Tue Nov 18, 2025 4:10 pm
T0biasCZe wrote: Tue Nov 18, 2025 3:35 pm Hi, could you please tell me if my BDR-209M is able to be flashed to be UHD capable?
OS device name: N:
Revision: 1.34
Thank you
PM sent.
joseacuna
#126 Post by joseacuna » Tue Nov 18, 2025 7:26 pm
Hi
Could you please tell me if my drive can be flashed to be UHD Capable?
Thanks.
OS device name: F:
Product: BD-RW BDR-209D
Revision: 1.51
Serial number:
Firmware date: 2018-05-08
Highest AACS version: 16
Drive platform: RS8601
Firmware version: 1.51/ID61
#127 Post by Coopervid » Tue Nov 18, 2025 7:44 pm
joseacuna wrote: Tue Nov 18, 2025 7:26 pm Hi
Thanks.
OS device name: F:
Revision: 1.51
Serial number:
PM is coming.
tresnugget
#128 Post by tresnugget » Thu Nov 20, 2025 4:21 pm
I also have a BDR-209M and would really appreciate some help flashing...
OS device name: E:
Revision: 1.51
Serial number: RLDL001398WL
Highest AACS version: 82
Firmware version: 1.51/ID60
#129 Post by Coopervid » Thu Nov 20, 2025 4:31 pm
tresnugget wrote: Thu Nov 20, 2025 4:21 pm I also have a BDR-209M and would really appreciate some help flashing...
OS device name: E:
Revision: 1.51
PM is coming.
Duck32150
#130 Post by Duck32150 » Mon Dec 08, 2025 10:57 am
Hello @Coopervid,
I also have a BDR-209M and would like to gain UHD capability by crossflashing it. I would be thankful for any help :)
OS device name: /dev/sr0
Revision: 1.34
Serial number: QADL047877WL
Highest AACS version: 63
#131 Post by Coopervid » Mon Dec 08, 2025 3:35 pm
Duck32150 wrote: Mon Dec 08, 2025 10:57 am Hello @Coopervid,
Revision: 1.34
PM sent.
Haksel
#132 Post by Haksel » Fri Dec 12, 2025 5:23 pm
Hello @Coopervid,
I have a BDR-209M inside of a ICY BOX IB-550StU3S 5.25 case and connected it via USB. I would love to gain the Ability to rip UHD and would be thankful for any Help :)
Revision: 1.20
Serial number:
Highest AACS version: 64
#133 Post by Coopervid » Fri Dec 12, 2025 7:48 pm
Haksel wrote: Fri Dec 12, 2025 5:23 pm Hello @Coopervid,
Revision: 1.20
Serial number:
PM sent.
korck
#134 Post by korck » Sat Dec 20, 2025 5:22 pm
Hi, could you tell me if my BDR-209M can be upgraded to be compatible with UHD?
Información de unidad de disco
Nombre del SO del dispositivo: F:
Fabricante: PIONEER
Producto: BD-RW BDR-209M
Revisión: 1.51
Número de serie: PFDL039672WL
Fecha del firmware: 2018-05-08
Marcas de cifrado bus: 13
#135 Post by Coopervid » Wed Dec 24, 2025 12:48 pm
korck wrote: Sat Dec 20, 2025 5:22 pm Hi, could you tell me if my BDR-209M can be upgraded to be compatible with UHD?
Fabricante: PIONEER
Revisión: 1.51
PM sent.
