Just scored a Buffalo-branded Pioneer BDR-209M
Intermodiate
Post by Intermodiate »
Given that Pioneer drives continue to be resolutely recommended despite being scarce as hens teeth, I wanted to share that I just purchased two Buffalo MediaStation BRXL-16U3 external drives and one was a Pioneer. The seller was "Woot" on Amazon. Probably old stock/overstock? The drive info:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 8.53
Serial number: Herpity
Firmware date: 2019-03-07
Highest AACS version: 66
Drive platform: RS8F00
Firmware version: 8.53/ID52
And...
Product: BD-RE BH16NS58
Revision: 1.02
Serial number: Derpity
Firmware date: 2119-02-23 09:35
Bus encryption flags: 1F
YMMV. Good luck if you decide to spin the wheel on it.
Unrelated - MakeMKV asked me to email the LG firmware to support@makemkv.com, which I did. Should I wait before trying to flash it?
Re: Just scored a Buffalo-branded Pioneer BDR-209M
Intermodiate wrote: Wed Nov 19, 2025 10:28 pm Given that Pioneer drives continue to be resolutely recommended despite being scarce as hens teeth, I wanted to share that I just purchased two Buffalo MediaStation BRXL-16U3 external drives and one was a Pioneer. The seller was "Woot" on Amazon. Probably old stock/overstock? The drive info:
Revision: 8.53
And...
Revision: 1.02
PM sent for your Pioneer. The LG can be flashed to LG WH16 NS60 1.02.
Intermodiate
I introduced your flasher to my Buffalo drive. They seemed to hit it off! They had a little chat. It wasn't long but it must have impressed my drive because after its nap it seems to be a new person. Thank you.
Product: BD-RW BDR-S12U
Revision: 1.02
Firmware date: 2022-03-07
Highest AACS version: 81
Drive platform: RS8F01
Firmware version: 1.02/ID43
Do you have any recommendations for changing the settings? Or would you just leave them alone?
Specifically I'm wondering if any of these meaningfully impact longevity or read performance/reliability.
Intermodiate
The LG went well too - thanks.
Product: BD-RE WH16NS60
Revision: 1.02
I don't actually have any UHD discs yet, so I didn't test that. The Pioneer started reading 1080p BDs a lot faster after the flash. The LG seems the same.
