OWC Mercury Pro Enclosure + BDR-S13JX Issue ?
zirch
Post by zirch »
I originally had a Vantec NexStar DX with a PIONEER BDR-212T, but after seeing posts about those enclosures possibly killing drives—and recommendations to use the OWC Mercury Pro, I switched. I modified the tabs so drive would fit, and my 212T has worked fine in the OWC
I recently got a BDR-S13JX. After swapping it into the same OWC enclosure, MakeMKV throws errors on start and when reading a disc. MakeMKV is current and using the latest SDF. I’ve tried power-cycling and rebooting.
Since the enclosure was recommended here and worked with my 212T, I was skeptical it was the issue, but to be thorough I pulled the S13JX out and tested it with a SATA-to-USB adapter, and it worked fine.
Full failing log (OWC enclosure + S13JX): MakeMKV_log.txt
Failing S13JX Drive:
Manufacturer: PIONEER
Product: BD-RW BDR-S13JX
Revision: 1.04
Serial number:
Firmware date: 2022-12-12
Highest AACS version: 61
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.04/ID72
Disc Information
Label: PREDATOR
Timestamp: 2018-05-16 15:18:43
Protection: AACS2.0/C v61
Data capacity: 59.57 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Working 212T Drive:
Product: BD-RW BDR-S12JX
Revision: 1.01
Serial number:
Firmware date: 2020-07-21
Drive platform: RS8F01
Firmware version: 1.01/ID72
Disc Information
Label: PREDATOR
Number of layers: 2
Am I missing something or is there something I need to do to have this enclosure working with the S13JX.
zirch
Re: OWC Mercury Pro Enclosure + BDR-S13JX Issue ?
Post by zirch »
Since posting I have tried:
Different USB cables, ports, and a hub
Disabling selective suspend/UASP power mgmt
Power supply (BDR-S13UBK 12V3A)
Running in Linux
No change.
I did also swap the drive into the BDR-S13UBK enclosure and it seems to work fine there - so definitely seems to be an isolated OWC + S13JX issue.
Does anyone else have this combination?
Is this a defective unit or will it be the same if I get it replaced?
zirch wrote: Fri Nov 21, 2025 1:22 am Since posting I have tried:
Running in Linux
No change.
Are you sure the OWC enclosure isn't a dud?
zirch
Post by zirch »
I’m not sure — I didn't think so, since it works fine with two different BDR-212T drives. I wasn't going to attempt an RMA if the replacement was going to behave the same, leading to me asking if anyone here has this exact combo working.
I did contact OWC support and they asked me to run their diagnostic tool, but it collects an extreme amount of unrelated system/personal data that I didn't want to share, so I asked them which specific parts they needed and I would provide them with that instead. Waiting on their reply.
i have had many s13ux/jx work fine in owc case but they were on 1.03
i think this is a libredrive issue on 1.04 i would have mike look at this
mike admin wrote: Sun Nov 16, 2025 1:36 am
zirch
Post by zirch »
Got it - thanks for the input. Think I’ll wait to see if Mike can take a look before circling back to OWC or requesting an RMA
