Frankenstein's Bloody Terror Blu-ray rip issue
Markbot
Post by Markbot » Wed Nov 19, 2025 9:46 pm
I have a blu-ray disc which was released September 2nd, 2025.
It's titled Frankenstein's Bloody Horror 3D (Kino Cult #35).
It's supposed to have 3 versions of the movie on the disc namely 2D, 3D and Anaglyphic 3D (red /cyan).
When I load it up in MakeMKV only 2 versions of the movie are detected as well as some extras.
The 2D, Anaglyphic 3D, and extras rip just fine, but the blu-ray 3D version is not present.
Examining the disc contents in Windows explorer shows a 7GB file named 00014.m2ts in the stream folder that doesn't get dumped.
Presumably this is the missing 3D version of the movie.
I tried copying that file to my hard drive and it seemed to copy, but I can't play it.
If there is anything I can do to help MakeMKV able to fully rip this disc please let me know.
Thanks for your help.
This is the log of the rip.
MakeMKV v1.18.2 win(x64-release) started
Downloading latest SDF to C:\Users\user/.MakeMKV ...
File 00006.mpls was added as title #0
File 00003.mpls was added as title #1
File 00008.mpls was added as title #2
Title #00004.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.mpls has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.mpls(1) has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.mpls(2) has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.mpls(3) has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00012.mpls was added as title #3
Title #00010.mpls has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00012.m2ts was added as title #4
File 00018.m2ts was added as title #5
Title #00025.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 6 titles into directory X:/Video/Frankenstein's Bloody Terror
6 titles saved
Markbot
Re: Frankenstein's Bloody Terror Blu-ray rip issue
Post by Markbot » Fri Nov 21, 2025 5:38 pm
Is there something I can do or provide to be able to get this blu-ray to back-up correctly?
I'd like to help if I can. The version I can't rip is the one I want most. LOL.
Post by Woodstock » Sun Nov 23, 2025 12:44 am
Question... Are you "Backing up" or "ripping files"?
Backup rips the entire disk to a directory.
It looks like you're trying to rip individual files, and you'll have to make sure you've enabled the rip of the 3D add-on by looking at the left-hand menu, and expand titles to see what's being ripped. When I last did a 3D title, that track wasn't in the default set.
