If people would just read the title text of each window that pops up there would be no issue!segfaulted wrote: Wed Nov 19, 2025 5:03 amb_m_hart wrote: Tue Nov 18, 2025 4:53 am Old drive died, so I got a new one, and flashed it. Here's the info:
OS device name: F:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: [snip]
Highest AACS version: 82
Firmware version: 1.03
No disc insertedI'll commentate on what I see...
Timestamps:
0:03 - Your drive identifies as a BP50NB40 1.03 and your opening post says "Firmware type: Patched" -- so you did okay with the WRITE portion.
0:05 - Since your drive is already running patched firmware, you don't need to do WRITE again. Move on to RECOVERY.
0:07 - Using WRITE to flash BP50NB40 to BU40N? That won't work. But like I said, move on to RECOVERY.
0:30 - This is where you made a mistake. You need to pick the firmware that's currently active on your drive: BP50NB40 1.03MK -- do not pick BU40N here.
0:34 - Yeah that's fine.
BP50NB40
Re: BP50NB40
