Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Hi Coopervid, I'd like my Verbatim drive to support UHD, would you also help me out? Many thanks!
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
OS device name: E:
Revision: 1.14
Serial number:
PM sent.gundelpfanne wrote: ↑Sun Nov 16, 2025 10:58 amHello i have a Problem with my BDR Pioneer.
Laufwerksinformation
OS-Gerätename: L:
Aktuelles Profil: DVD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.11
Serienummer:
Firmware-Datum: 2018-11-28
Firmware version: 1.11
Keine Disk eingelegt
Can i have the modded Firmware.
Thank You
mfg gundelpfanne
PM sent.symseven wrote: ↑Sun Nov 16, 2025 7:30 pmHi Coopervid, I'd like my Verbatim drive to support UHD, would you also help me out? Many thanks!
OS device name: E:
Revision: 1.14
Serial number:
Hi Coopervid, I just bought this drive thinking it supported UHD but I tried a disc and nothing happened. like my Verbatim drive to support UHD, would you also help me out? Many thanks!
OS device name: E:
Product: BD-RE BU40N
Revision: 1.03
Serial number:
Firmware version: 1.03
OS device name: E:
Revision: 1.03
Serial number:
Your drive is already libredrive enabled and UHD ready. If it won't read UHD discs you have some other issue. Try pasting MakeMKV's log window text when attempting to rip a UHD disc and we might be able to help further.GRS97 wrote: ↑Wed Nov 26, 2025 10:46 amHi Coopervid, I just bought this drive thinking it supported UHD but I tried a disc and nothing happened. like my Verbatim drive to support UHD, would you also help me out? Many thanks!
OS device name: E:
Revision: 1.03
Serial number:
Also, you should insert the disc and let the OS initiialise it (you should see it in windows explorer) before you open MakeMKV.
Hi, I got a Verbatim 43889 with the following Information. What are the steps for making it UHD ready?
Thanks a lot for support.
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.14
Serienummer: ALDL....
Firmware-Datum: 2020-06-15
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.14
PM sent.Sam1969 wrote: ↑Fri Nov 28, 2025 2:05 amHi, I got a Verbatim 43889 with the following Information. What are the steps for making it UHD ready?
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.14
StarryEyed
My optical drive has recently failed so looking to get a replacement. Before purchasing can I ask a sanity check please: if I get a Verbatim 43890 will I be able to flash this drive myself?
If it's new stock it contains a LG BU40N and you can flash it according to the UHD guide. If it's old stock it might contain a Pioneer UD03 and you have to post again so I will forward a package to flash it.StarryEyed wrote: ↑Fri Nov 28, 2025 1:41 pmMy optical drive has recently failed so looking to get a replacement. Before purchasing can I ask a sanity check please: if I get a Verbatim 43890 will I be able to flash this drive myself?
I just purchased a Verbatim 43890 drive and I'm looking for some assistance to make it UHD capable. My drive information is listed below. Thank you in advance.
OS device name: F:
Revision: 1.14
Serial number:
OS device name: F:
Revision: 1.14
Serial number:
PM sent.wizrd54 wrote: ↑Wed Dec 03, 2025 10:59 pmI just purchased a Verbatim 43890 drive and I'm looking for some assistance to make it UHD capable. My drive information is listed below. Thank you in advance.
OS device name: F:
Revision: 1.14
Serial number:
just got this drive and its not reading uhd disks
Revision: 1.14
Serial number:
Revision: 1.14
Serial number:
Please don't post the same thing in multiple threads. Your other post has been answered.ahaddadin wrote: ↑Thu Dec 04, 2025 11:39 pmjust got this drive and its not reading uhd disks
Revision: 1.14
Serial number:
OS device name: F:
Revision: 1.14
Serial number:
Highest AACS version: 68
OS device name: F:
Revision: 1.14
Serial number:
PM sent.bdr485 wrote: ↑Sat Dec 06, 2025 1:22 amI just purchased a Verbatim 43890 drive and I'm looking for some assistance to make it UHD capable. My drive information is listed below. Thank you in advance.
OS device name: F:
Revision: 1.14
Serial number:
