Ripping Se7en 4K
vdog01
Ripping Se7en 4K
Post by vdog01 »
Hi all
Just wanted to let you know that I was getting read errors when trying to rip the 4K UHD disc of Se7en.
After I put in the "secret" registry entry of ioIgnoreReadErrors with a REG_DWORD value of 1, it continued to rip the disc with the errors which look something like
004004:0000 The source file '/BDMV/STREAM/00079.m2ts' is corrupt or invalid at offset 17595432960, attempting to work around
I just watched the entire rip and it appeared to be successfully ripped. So I guess if you have errors, just get MakeMKV to continue to read and hopefully it'll successfully create an MKV file for you
Re: Ripping Se7en 4K
vdog01 wrote:
Sat Oct 11, 2025 10:53 pm
Hi all
Usually cleaning the disc help with read errors. I had no issue at all ripping mine.
vdog01
Post by vdog01 »
MartyMcNuts wrote:
Sun Oct 12, 2025 12:14 am
Hi all
Yeah, I tried cleaning the disc multiple times, but still got the errors :oops:
Either way, by telling MakeMKV to ignore the error, it seemed to work
