Flashing Pioneer BDR-212D
zdjh22
Re: Flashing Pioneer BDR-212D
Post by zdjh22 »
Yet another Pioneer BDR-212M, my workhorse for non-UDF. I would love to be able to use this for UDF discs as well.
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-212M
Revision: 1.00
Serial number: SKDL000579WL
Firmware date: 2019-01-10
Highest AACS version: 82
Drive platform: RS8F00
Firmware version: 1.00/ID56
zdjh22 wrote: Mon Nov 17, 2025 5:08 pm Yet another Pioneer BDR-212M, my workhorse for non-UDF. I would love to be able to use this for UDF discs as well.
OS device name: H:
Revision: 1.00
You mean UHD. PM sent.
zdjh22
Post by zdjh22 »
Coopervid wrote: Mon Nov 17, 2025 7:30 pm
Thanks! Worked perfectly.
I must have meant UDF filesystems on UHD discs! Yeah - that's the ticket :)
reelmccoy
Post by reelmccoy »
Finally got the nerve to plug in my BDR-212D (via usb 3.x) and put makemkv to use. Was curious to see if there was a firmware update and found this thread. I'm game to update. :)
OS device name: G:
Current profile: DVD-ROM
Product: BD-RW BDR-212D
Revision: 1.02
Serial number:
Firmware date: 2022-03-16
Bus encryption flags: 13
Firmware version: 1.02/ID61
Thanks a ton!
ReelMcCoy - Enjoying life one bit at a time.
ember1205
Post by ember1205 »
I have the exact same drive with all of the same specs...
OS device name: E:
Revision: 1.02
Serial number:
ember1205 wrote: Wed Jan 21, 2026 7:38 pm I have the exact same drive with all of the same specs...
OS device name: E:
Revision: 1.02
Serial number:
reelmccoy wrote: Wed Jan 21, 2026 6:13 pm Finally got the nerve to plug in my BDR-212D (via usb 3.x) and put makemkv to use. Was curious to see if there was a firmware update and found this thread. I'm game to update. :)
OS device name: G:
Revision: 1.02
Serial number:
Thanks a ton!
Sure just email me that makemkv drive info section see below for email
DC-2187
Post by DC-2187 »
I was wondering if I can get some help on getting this drive flashed.
Revision: 1.02
Serial number: DEDL055897WL
DC-2187 wrote: Thu Jan 22, 2026 2:13 am Hello,
Revision: 1.02
yes same as the others just email me that drive info section see below
CMoney
Post by CMoney »
Hello.
Can I get some help to flash this to read UHD? I think it can be flashed to read UHD. I happen to luck out and find one to purchase. In the past I have flashed LG and ASUS drives with SDFTool but I could not find firmware version and instructions on the forums.
Revision: 1.02
Serial number: DGDL........
Hope to get fewer read errors than my ASUS and LG drives.
Thank you
CMoney wrote: Fri Jan 30, 2026 8:56 pm Hello.
Revision: 1.02
Thank you
Yes just email me that drive info section see below for email
