LibreDrive for Pioneer drives
Lbrtydrmr wrote: Mon Nov 17, 2025 12:32 am Drive Information
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.51
Serial number: SGDL054873WL
Firmware date: 2018-05-08
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: RS8601
Firmware version: 1.51/ID61
PM is coming.
MicAel1
Post by MicAel1 »
Thank you for all your efforts! Today I received my Pioneer drive and would also like to cross flash it in order to enable UHD support.
This is the drive information:
OS device name: /dev/sr2
Revision: 1.33
Serial number: OFDL********
Firmware date: 2015-12-09
Highest AACS version: 82
Drive platform: RS8600
Firmware version: 1.33/ID61
Is there a way to flash it from Linux as well? (Otherwise I briefly install Windows.)
Thanks in advance!
MicAel1 wrote: Tue Nov 18, 2025 5:41 pm Thank you for all your efforts! Today I received my Pioneer drive and would also like to cross flash it in order to enable UHD support.
Revision: 1.33
Thanks in advance!
PM sent.
MicAel1
Post by MicAel1 »
Thanks, this worked flawlessly! I used Windows 10 in Gnome Boxes and simply forwarded the USB adapter (JMicron JMS583Gen 2 to PCIe Gen3x2 Bridge) to the VM.
Result:
OS device name: /dev/sr1
Product: BD-RW BDR-S11
Revision: 1.53
Firmware date: 2020-08-03
Drive platform: RS8800
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID43
I also succesfully ripped the first UHD disk that caused me some issues on the previous drive (one of these slimline Verbatim ones).
acs871
Post by acs871 »
Please assist with the upgrade of Pioneer drive to read UHD.
OS device name: E:
Product: BD-RW BDR-209M
Revision: 1.50
Serial number: QLDL********
Firmware date: 2017-12-21
Drive platform: Pioneer RS8601
Firmware version: ID60
MinistryOfMagic
Post by MinistryOfMagic »
Hi, can someone please help me activate Libredrive and UHD (if possible) with the following drive.
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: DHDL********
Firmware date: 2022-12-27
Drive platform: Pioneer RS9331
Firmware version: ID05
Last edited by MinistryOfMagic on Sat Nov 22, 2025 1:47 am, edited 1 time in total.
MinistryOfMagic wrote: Sat Nov 22, 2025 1:10 am Hi, can someone please help me activate Libredrive and UHD (if possible) with the following drive.
Revision: 1.02
Serial number: DHDL006091UC
This should already be enabled. As it is not, you need to download the latest SDF.bin and put it in the MakeMKV data directory. Restart MakeMKV and it should be absorbed in to _private_data.tar and the drive should be libredrive enabled.
acs871 wrote: Fri Nov 21, 2025 3:37 pm Hi,
OS device name: E:
Revision: 1.50
PM sent.
daerelas
Post by daerelas »
May I please ask as well for help in getting this to work? Here is my MakeMKV info:
OS device name: F:
Revision: 1.31
Serial number: OHDL********
Firmware date: 2015-05-25
Firmware version: 1.31/ID60
daerelas wrote: Sat Nov 22, 2025 9:26 pm May I please ask as well for help in getting this to work? Here is my MakeMKV info:
OS device name: F:
Revision: 1.31
PM sent.
acs871
Post by acs871 »
Coopervid wrote: Sat Nov 22, 2025 12:24 pm
OS device name: E:
Revision: 1.50
PM sent.
Thank you very much. UHD's are being read.
BrantleyF
Post by BrantleyF »
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DIDL1*******
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E113/ID76
With thanks in advance
Brantley
BrantleyF wrote: Tue Nov 25, 2025 2:56 pm Hi,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Brantley
PM sent.
Apollo821
Post by Apollo821 »
Hello, friends!
I've got an XD08...is this flashable or otherwise upgradeable to rip UHDs? I'm a little lost.
Revision: 1.02
Serial number:
Highest AACS version: 60
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02
Apollo821 wrote: Wed Nov 26, 2025 1:52 am Hello, friends!
Revision: 1.02
Serial number:
No. The firmware is post 11/2022 and cannot be cross-flashed at this stage. You will have to wait for possible future cross-flash support.
