Any suggestions with the following error? Thanks in advance.
MakeMKV v1.7.2 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command 46020..00140 to device 'SPTI:\Device\CdRom1'
Loaded 33 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00003.svq
Failed to process BD+ code using generic SVQ from builtin/00003.svq
Processing BD+ code using generic SVQ from builtin/00002.svq
BD+ code processed but no FUTs were obtained, errors may follow
File 00800.mpls was added as title #0
Title #00720.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.mpls has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00850.mpls is equal to title 00800.mpls and was skipped
File 00470.mpls was added as title #1
Title 00449.mpls is equal to title 00470.mpls and was skipped
Title #00061.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00720.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00450.m2ts was added as title #2
File 00453.m2ts was added as title #3
File 00454.m2ts was added as title #4
File 00455.m2ts was added as title #5
File 00456.m2ts was added as title #6
File 00457.m2ts was added as title #7
File 00458.m2ts was added as title #8
File 00465.m2ts was added as title #9
File 00462.m2ts was added as title #10
Title #00463.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00464.m2ts was added as title #11
Title #00466.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00467.m2ts was added as title #12
Title #00468.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Users/***/Desktop/Martha_Marcy_May_Marlene
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 59412480, attempting to work around
DEBUG: Code 0 at o`xW9rJK2r$9HlA.biDE:213133158
DBG ASSERT: XD0yI:;V%?VIY1}+Xq/l#6T@OC4`,0:SDh<nUc!Lb|3J0Ug[$v*n/Gh mlhGR<`3^4_CE*UMvjE==#9 at o`xW9rJK2r$9HlA.biDE:121264487
DEBUG: Code 2 at o`xW9rJK2r$9HlA.biDE:213134952
DEBUG: Code 0 at S:W@%$u@]S\7PaQ8ZSe*U:29397955
DEBUG: Code 0 at !`QAcCmf{*Gx'}XU~?!:213132031
Failed to save title 0 to file C:/Users/***/Desktop/Martha_Marcy_May_Marlene/t00_Martha_Marcy_May_Marlene.mkv
0 titles saved, 1 failed
Error on Martha Marcy May Marlene
Re: Error on Martha Marcy May Marlene
A new BD+ protection, SVQ should be updated tomorrow.
