Asus SBW-06D5H-U - reading speed
RexCramer
Post by RexCramer »
i've an external/portable slim usb drive (see topic). My problem is the limited reading speed (only 2x) while ripping blu rays to ssd. I know that the reading/ripping speed is reduced on porpose by the manufactures but i'm very annoyed about that fact.
Is anybody here, who can help with a patched firmware?
I would really appreciate some feedback. Thank you so much for your support.
zittrig
Re: Asus SBW-06D5H-U - reading speed
Post by zittrig »
Please post your MakeMKV drive infos first.
RexCramer
Post by RexCramer »
Here is the information directly from MKV:
Aktuelles Profil: BD-ROM
Produzent: ASUS
Produkt: SBW-06D5H-U
Revision: E101
Serienummer: -
Firmware-Datum: 2018-08-22
Drive platform: RS8511
Firmware version: E101/ID26
Keine Disk eingelegt
In case there is a firmware patch for getting rid of the restriction of low ripping speed, i'm not very experienced how to handle the patching process.
Means: i need help for that
Thanx o lot for your support
RexCramer wrote:
Mon Nov 17, 2025 4:45 pm
Produzent: ASUS
Revision: E101
Serienummer: -
PM sent for upgrading it for UHD. If the reading speed issue after that is not solved, read this:
viewtopic.php?f=19&t=22689
RexCramer
Post by RexCramer »
Thanks a lot for support drive issues with slow reading speed. After patching everything works fine - problem solved - donate done :D
