Pioneer UHD BDR-S11JX from China
frodobagginz
#1 Post by frodobagginz » Sat Nov 15, 2025 9:36 am
Hello, I'm trying to buy a few Pioneer UHD drives that will work with MakeMKV. I see some Pioneer UHD BDR-S11JX available from China on eBay. Mike's announcement says that most Pioneer UHD drives should work now. Does anyone know if this is true for all firmware versions of this drive? I'm asking because the seller doesn't specify which firmware the drives have. Cheers
zittrig
Re: Pioneer UHD BDR-S11JX from China
#2 Post by zittrig » Sat Nov 15, 2025 10:30 am
Without a look to the MakeMKV drive informationit it's a glass ball prediction.
You can risk it or perhaps the seller is answering the question about the installed firmware.
Batman&throbbin
#3 Post by Batman&throbbin » Sat Nov 15, 2025 10:47 am
If you’re in the UK try eBay for used examples, much more trustworthy
#4 Post by Coopervid » Sat Nov 15, 2025 12:02 pm
There is a high chance to get scammed. Better wait for Asmcom to reopen his site and buy from him.
viewtopic.php?f=20&t=19387&start=1410
frodobagginz
#5 Post by frodobagginz » Sat Nov 15, 2025 12:46 pm
Thanks for the info everyone
Voxelium
#6 Post by Voxelium » Thu Dec 11, 2025 10:44 pm
Hi, I took the risk and purchased one.
It does read 4K.
Firmware is dated 2020.
It seems to be legitimate as far as I can tell.
It also burns 100GB BDXLs.
Libredrive looks to function as well.
MAKEMKV INFO:
OS device name: E:
Current profile: BD-R SRM
Manufacturer: PIONEER
Product: BD-RW BDR-S11
Revision: 1.53
Serial number: PIDL140759WL
Firmware date: 2020-08-03
Highest AACS version: 77
Drive platform: RS8800
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID43
Disc Information
Label: (REMOVED FOR PRIVACY REASONS)
Timestamp: 2023-04-15 15:35:17
Data capacity: 93.22 Gb
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• PANASONIC SW-9576-C
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
Timeless
#7 Post by Timeless » Tue Jan 06, 2026 3:41 am
Thank you Voxelium for the heads up on this! I've gone ahead and done the same. As it's getting pretty hard to find a decently priced UHD bluray drive for PC, and I definitely want to be prepared in case mine fails in the future.
I appreciate you!
VirtualStudio
#8 Post by VirtualStudio » Tue Jan 06, 2026 8:44 am
It does read 4K.
MAKEMKV INFO:
OS device name: E:
Revision: 1.53
Disc Information
Hi, are those the ones which you bought, please?
Thanks..
https://www.ebay.com/itm/394955321603
phantom0308
#9 Post by phantom0308 » Wed Jan 07, 2026 1:01 am
Thanks..
I live in China. To be honest, this looks like something made by those renovators in Foshan/Guangzhou. These optical drives might only cost 450 RMB in China. Also, the special back sticker that is unique to the Pioneer model was not found...
My friend has bought one. It works fine for reading UHD files, but its reliability needs further observation.
Timeless
#10 Post by Timeless » Wed Jan 14, 2026 1:24 am
Thanks Phantom for the heads up. By comparison, this Pioneer drive reads faster than my LG WH16NS40. So, perhaps, that's a good sign.
