Pioneer UHD BDR-S11JX from China
frodobagginz
Hello, I'm trying to buy a few Pioneer UHD drives that will work with MakeMKV. I see some Pioneer UHD BDR-S11JX available from China on eBay. Mike's announcement says that most Pioneer UHD drives should work now. Does anyone know if this is true for all firmware versions of this drive? I'm asking because the seller doesn't specify which firmware the drives have. Cheers
zittrig
Re: Pioneer UHD BDR-S11JX from China
Without a look to the MakeMKV drive informationit it's a glass ball prediction.
You can risk it or perhaps the seller is answering the question about the installed firmware.
Batman&throbbin
If you’re in the UK try eBay for used examples, much more trustworthy
There is a high chance to get scammed. Better wait for Asmcom to reopen his site and buy from him.
viewtopic.php?f=20&t=19387&start=1410
frodobagginz
Thanks for the info everyone
Voxelium
Hi, I took the risk and purchased one.
It does read 4K.
Firmware is dated 2020.
It seems to be legitimate as far as I can tell.
It also burns 100GB BDXLs.
Libredrive looks to function as well.
MAKEMKV INFO:
OS device name: E:
Current profile: BD-R SRM
Manufacturer: PIONEER
Product: BD-RW BDR-S11
Revision: 1.53
Serial number: PIDL140759WL
Firmware date: 2020-08-03
Highest AACS version: 77
Drive platform: RS8800
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID43
Disc Information
Label: (REMOVED FOR PRIVACY REASONS)
Timestamp: 2023-04-15 15:35:17
Data capacity: 93.22 Gb
It does read 4K.
MAKEMKV INFO:
OS device name: E:
Revision: 1.53
Disc Information
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• PANASONIC SW-9576-C
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
Timeless
Thank you Voxelium for the heads up on this! I've gone ahead and done the same. As it's getting pretty hard to find a decently priced UHD bluray drive for PC, and I definitely want to be prepared in case mine fails in the future.
I appreciate you!
I appreciate you!
VirtualStudio
Hi, are those the ones which you bought, please?Voxelium wrote: Thu Dec 11, 2025 10:44 pm Hi, I took the risk and purchased one.
It does read 4K.
MAKEMKV INFO:
OS device name: E:
Revision: 1.53
Disc Information
Thanks..
https://www.ebay.com/itm/394955321603
phantom0308
I live in China. To be honest, this looks like something made by those renovators in Foshan/Guangzhou. These optical drives might only cost 450 RMB in China. Also, the special back sticker that is unique to the Pioneer model was not found...VirtualStudio wrote: Tue Jan 06, 2026 8:44 am Hi, are those the ones which you bought, please?
Thanks..
My friend has bought one. It works fine for reading UHD files, but its reliability needs further observation.
Timeless
Thanks Phantom for the heads up. By comparison, this Pioneer drive reads faster than my LG WH16NS40. So, perhaps, that's a good sign.
najeeb
I ended buying what was advertised as a BDR-S11X from a U.S. eBay seller- and it's even labeled as such on the exterior of the drive. After removing the eight-year-old LG drive from the external Vantec USB-3.0 enclosure and replacing it with the Pioneer, MakeMKV recognized the drive and reported it to be a BDR-211. It worked right after installation, not requiring a flash or downgrade. I tested it by backing up the most troublesome of discs that I have - TRUE LIES. It was successful and completed the process in about 90 minutes. This is a disc that the LG could not read properly and failed. Also, the replacement Pioneer is much quieter and, so far, speedier. Was this Pioneer a new drive? Who knows. It was obviously an OEM unit in the original sealed plastic wrap. No exterior wear or scratches. So, I guess there is new inventory of some sort out there in the wild. Here is what MakeMKV reports. I am very pleased with the drive so far.
Revision: 1.53
Serial number:
Highest AACS version: 82
Revision: 1.53
Serial number:
Trust me it was just recased they have a huge fake operation going over therenajeeb wrote: Mon Feb 16, 2026 10:35 pm I ended buying what was advertised as a BDR-S11X from a U.S. eBay seller- and it's even labeled as such on the exterior of the drive. After removing the eight-year-old LG drive from the external Vantec USB-3.0 enclosure and replacing it with the Pioneer, MakeMKV recognized the drive and reported it to be a BDR-211. It worked right after installation, not requiring a flash or downgrade. I tested it by backing up the most troublesome of discs that I have - TRUE LIES. It was successful and completed the process in about 90 minutes. This is a disc that the LG could not read properly and failed. Also, the replacement Pioneer is much quieter and, so far, speedier. Was this Pioneer a new drive? Who knows. It was obviously an OEM unit in the original sealed plastic wrap. No exterior wear or scratches. So, I guess there is new inventory of some sort out there in the wild. Here is what MakeMKV reports. I am very pleased with the drive so far.
Revision: 1.53
Serial number:
najeeb
Figuratively speaking, that didn't take long for them to do, no? I guess the Japan demand must be working out for them.Billycar11 wrote: Tue Feb 17, 2026 12:21 am Trust me it was just recased they have a huge fake operation going over there
Those drives are years old they stopped making 211 back in like 2019 they have had years to do this but they probably started back in 2023 when someone leaked the pioneer crossflasher to themnajeeb wrote: Tue Feb 17, 2026 11:42 pmFiguratively speaking, that didn't take long for them to do, no? I guess the Japan demand must be working out for them.Billycar11 wrote: Tue Feb 17, 2026 12:21 am Trust me it was just recased they have a huge fake operation going over there
Finray
I bought the same drive from Newegg a seller that ships from China. This is what i got -
"Drive Information
Revision: 1.53
Serial number: MED********
Highest AACS version: 76"
"LibreDrive Information
Drive platform: Pioneer RS8801
Firmware version: ID43"
"Disc Information
Label: SCOTTPILGRIM_UPK75
Timestamp: 2021-05-06 13:06:40
Protection: AACS2.0/C v76
Data capacity: 91.62 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80"
This is what BDRFlash shows -
[Pioneer BD-RW BDR-s11 1.53 20/08/03]
"Product code BDR-208MBK
Harware Type SAT 8801
Kernal Type ID43
Firmware type ID43
Kernal version 0000"
So, im guessing this is a different drive with spoofed FW?. Assuming i cant return it, what do you guys think?
Also, if this is an old drive from 2013 then why is it a 8801?...i thought that was newer V2?.
It does work in reading UHD discs but of course MMKV cant decrypt them?...im guessing?. I just get a bunch of "SCSI invalid commands"
EDIT: Umm okayy... Now it works all the sudden in MMKV and its playing the UHD film in VLC. Please explain that one somebody.
Oh, BTW and FWIW I am more interested in just watching my UHD Blu Rays directly from the disc on my HTPC right now. Ripping will be a future activity when i add a ton of storage.
Thank You in advance to anyone that can help me out here, or just offer their two cents.
"Drive Information
Revision: 1.53
"Disc Information
Number of layers: 3
Kernal Type ID43
Firmware type ID43
