Just downloaded and installed MakeMKV BETA and I am getting the following problem:
The application reads the unenencrypted Blu-Ray disc ok (XMen 3) but when I press the Make MKV button I get the following message:
MakeMKV v1.4.6 beta win(x86-release) started
AACS directory not present, assuming unencrypted disc
File 00000.mpls was added as title #0
Operation sucessfully completed
Saving 1 titles into directory K:/Video/XMEN3_F1
Failed to save title 0 to file K:/Video/XMEN3_F1/title00.mkv
0 titles saved, 1 failed
Please help.
- Contact:
Re: Failed to save title 0 to file
This error is most likely due to an incorrectly mastered blu-ray disc. In order to confirm, please open preferences dialog, enable "log debug messages", restart the program, try to open these files again and post the produced log here.
I can confirm this error (Bug?). As long as the Bluray files on harddisk use an VC-1 video stream, everything ist fine.
As soon as the video in the m2ts file is encoded in AVC the error message appears and the mkv creation aborts.
- Contact:
This is correct. Blu-ray discs must contain AccessUnit NAL units in AVC video stream. Re-encoded "pirate blu-rays" often lack this information and MakeMKV fails on them.
I had this error a couple of times. Each time I rebooted my pc and wiped off the disc and tried again. Each time it worked fine after that.
I get the failed to save title 0 to file everytime with Bluray disc First Blood;
Log file.
Debug log started at Fri Nov 13 00:54:21 2009 , written by MakeMKV v1.4.8 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.8 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\Todd/MakeMKV_log.txt
003010:000000:0000 Using direct disc access mode
003310:000000:0000 AACS directory not present, assuming unencrypted disc
003020:000000:0000 Title #00000.mpls has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003316:000000:0000 Only extracting DTS core audio from stream #2 of type 'DTS-HD audio' in file 00001.m2ts
003313:000000:0000 File 00001.mpls was added as title #0
003313:000000:0000 File 00012.mpls was added as title #1
003020:000000:0000 Title #00000.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00003.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00005.m2ts was added as title #2
003020:000000:0000 Title #00006.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00009.m2ts was added as title #3
003313:000000:0000 File 00010.m2ts was added as title #4
003020:000000:0000 Title #00015.m2ts has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00016.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00018.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory C:/Video
001012:000000:0020 FAILURE: Code 49 at 1fXrukp|B?%VDS)|Cv5:213133365
FS ID=V_MPEG4/ISO/AVC C=49
001012:000000:0020 FAILURE: Code 0 at &]vQ?j]):Kn4LyoN5S0Cl:121264211
001011:000000:0020 LIBMKV_TRACE: Exception: Error while reading input
005003:000000:0000 Failed to save title 0 to file C:/Video/title00.mkv
005004:000000:0000 0 titles saved, 1 failed
005037:000000:0204 Copy complete. 0 titles saved, 1 failed.
Log file.
- Contact:
it looks like something is wrong with an mpeg-4 video stream. to diagnose we would need to look at actual video frames that cause the problem but it looks like 49 lines with this information were removed from a log file.
attached is the entire log file
I have even tried ripping the bluray to the hard drive and then running makemkv from the hard drive but I get the same error.
It errors at the exact same part (as soon as the mkv file gets to 230mb it errors and stops).
I have tried 2 different First Blood bluray discs.
Other discs work fine.
Thanks for any assistance.
