Asus BW-16D1X-U
Re: Asus BW-16D1X-U
#286 Post by MartyMcNuts » Thu Nov 13, 2025 10:07 pm
Tri0ptic wrote: Thu Nov 13, 2025 6:06 pm Thank you for the PM. When I start BDRFlash it says “No available devices found.” MakeMKV still sees it. There is no disc inside and it is closed. This is on Windows 11.
Without a disc, MakeMKV reports this:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: D*
Firmware date: 2020-07-21
Highest AACS version: 72
Drive platform: RS8F00
Firmware version: E113/ID76
Any suggestions? Thank you, again.
Make sure you check the force flash box.
Re: Asus BW-16D1X-U
#287 Post by MartyMcNuts » Thu Nov 13, 2025 10:09 pm
thebryantfisher wrote: Thu Nov 13, 2025 9:31 pm Hi all
Thanks in advance for your help. Very new to all of this. I have been reading through the forums and there are many variations of similar drives and wanted to get a sense of whether this one if UHD capable.
What one? You need to copy and paste the drive info and libredrive info sections.
Tri0ptic
Re: Asus BW-16D1X-U
#288 Post by Tri0ptic » Fri Nov 14, 2025 7:19 am
MartyMcNuts wrote: Thu Nov 13, 2025 10:07 pm Make sure you check the force flash box.
Thanks but the check box is not enabled.
Re: Asus BW-16D1X-U
#289 Post by Coopervid » Fri Nov 14, 2025 12:59 pm
Tri0ptic wrote: Fri Nov 14, 2025 7:19 am
The program can't find your drive - which is weird. Have you tried different USB ports and power is on?
Tri0ptic
Re: Asus BW-16D1X-U
#290 Post by Tri0ptic » Fri Nov 14, 2025 6:59 pm
Thanks for the reply. Yes, it was on, etc. I tried different cables and I have tried 3 PCs. Finally my girlfriend’s ARM-based laptop worked and I was able to flash it. Just to be sure here is the new info from MakeMKV (running on the PC that BDRFlash does NOT work on) and a screenshot from BDRFlash after flashing (running on the ARM laptop). If you would not mind just verifying all is well… Thanks!
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.02
Serial number: D*
Firmware date: 2022-03-07
Drive platform: RS8F01
Firmware version: 1.02/ID43
Re: Asus BW-16D1X-U
#291 Post by Coopervid » Fri Nov 14, 2025 11:39 pm
Tri0ptic wrote: Fri Nov 14, 2025 6:59 pm Thanks for the reply. Yes, it was on, etc. I tried different cables and I have tried 3 PCs. Finally my girlfriend’s ARM-based laptop worked and I was able to flash it. Just to be sure here is the new info from MakeMKV (running on the PC that BDRFlash does NOT work on) and a screenshot from BDRFlash after flashing (running on the ARM laptop). If you would not mind just verifying all is well… Thanks!
OS device name: G:
Revision: 1.02
Serial number: D*
Weird - but all is well.
albaloo
Re: Asus BW-16D1X-U
#292 Post by albaloo » Sat Nov 15, 2025 5:57 am
Hello everyone,
I recently bought a BW-16D1X-U drive. Here is the information for the drive.
OS device name: /dev/rdisk5
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Highest AACS version: 35
Firmware version: E116/ID71
Is it possible to flash this version?!
I am sorry but I couldn't find how can I find and download BDRFlash.
Thank you for your support
Re: Asus BW-16D1X-U
#293 Post by Coopervid » Sat Nov 15, 2025 11:20 am
albaloo wrote: Sat Nov 15, 2025 5:57 am Hello everyone,
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.
albaloo
Re: Asus BW-16D1X-U
#294 Post by albaloo » Sat Nov 15, 2025 4:53 pm
Coopervid wrote: Sat Nov 15, 2025 11:20 am PM sent.
Thank you so much, sorry but I made a mistake my drive is BW-16D1H-U not 1X.
Do I need to use Asus BW-16D1HT 3.10MK firmware file with BDRFlash to flash the drive?
Re: Asus BW-16D1X-U
#295 Post by Coopervid » Sat Nov 15, 2025 5:39 pm
albaloo wrote: Sat Nov 15, 2025 4:53 pm
Go ahead with the download and you will be fine. This is a Pioneer not a LG.
joe_k
Re: Asus BW-16D1X-U
#296 Post by joe_k » Mon Nov 17, 2025 3:31 pm
Hey all. Long time lurker here.
I picked up this drive yesterday after my LG started to fail. It seems the working instructions are being pm'd out? Would someone mind fwding them to me?
Re: Asus BW-16D1X-U
#297 Post by Woodstock » Mon Nov 17, 2025 4:02 pm
At a guess, I'd say the reason things are being sent via private messages has to do with the fact that "the fix" varies with the drive... and sending the WRONG "fix" to someone could brick their drive.
Re: Asus BW-16D1X-U
#298 Post by Coopervid » Mon Nov 17, 2025 4:30 pm
joe_k wrote: Mon Nov 17, 2025 3:31 pm Hey all. Long time lurker here.
I piicked up this drive yesterday after my LG started to fail. It seems the working jnstructions are being pm'd out? Would someone mind fwding them to me?
You need to post your Makemkv info to get a tailored package for your drive.
joe_k
Re: Asus BW-16D1X-U
#299 Post by joe_k » Mon Nov 17, 2025 7:02 pm
Coopervid wrote: Mon Nov 17, 2025 4:30 pm You need to post your Makemkv info to get a tailored package for your drive.
Manufacturer: Asus
Product: BW-16D1X-U
Revision: A 105
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Re: Asus BW-16D1X-U
#300 Post by Coopervid » Mon Nov 17, 2025 7:19 pm
joe_k wrote: Mon Nov 17, 2025 7:02 pm
Manufacturer: Asus
Product: BW-16D1X-U
Revision: A 105
This is a LG drive. Look here:
viewtopic.php?f=16&t=19634
