BDR 212V UHD Guide
Re: BDR 212V UHD Guide
TnEGuy wrote: Wed Nov 05, 2025 2:14 am Hello Coopervid,
I just received the following drive:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: DGDL027890WL
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 76
Firmware version: ID06
I have seen very similar drive information posted by others in this thread. Given your responses to them it appears as if this drive can be flashed to read UHD disks.
I also recently acquired a Pioneer BDR-212DBK drive a few weeks ago. You gave me the flasher and firmware for flashing that drive. (Thanks again. That drive works perfectly!)
The pre-flash BDR-212DBK drive info was:
Product: BD-RW BDR-212D
Revision: 1.02
Firmware Date: 2022-03-16
Drive platform: RS8F00
Firmware version: 1.02/ID61
Just to be sure, can my new BDR-212V drive be flashed? If so, should the BDR-212V drive be flashed using the same flasher and firmware as the BDR-212-DBK drive? If not, would you please PM me with the right stuff again?
As always, I'm very grateful for all of the guidance and help you are willing to provide!
Yes. Go ahead.
TnEGuy
Post by TnEGuy »
Cool! I'd thought maybe so after reading the tutorial.
One other question if I may? I realize that this might be a bit outside of the forum's scope.
Does the current Vinpower firmware on this BDR-212V drive make a real-world quality difference when burning disks? I'm considering using optical disks as low-volume backup media so my most critical files can easily, securely, and reliably be stored off-site. Totally retro, huh?
If this drive can actually burn "better" disks as is, I might not flash it.
Unfortunately, I don't understand the technical info that's shown on the sales websites well enough to discern a meaningful context. They all show the exact same pictures.
With all of the reverse engineering that some people on this forum have done, maybe they'd have an opinion about this they're willing to share?
Thanks again for all of the help so far.
TnEGuy wrote: Thu Nov 06, 2025 5:03 am Cool! I'd thought maybe so after reading the tutorial.
No, the 212V has just some mechanical modifications / benefits that makes it more robust. Write strategies among the Pioneer drives are pretty much identical. If you burn to multi-layer discs you should read what I link here. Not necessary for single layer discs.
kitahoshi posted a copy from the Redfox forum.
https://forum.doom9.org/showthread.php?t=185539&page=19
P.S.: I have also 212V firmware to flash it back when converted to UHD.
TnEGuy
Post by TnEGuy »
Man! That link has a lot to absorb. I'll be reading it multiple times.
You guys are into this stuff deep! Thx for sharing!
Good to know I can flash the drive back to original if desired. Would you mind hooking me up with the 212V firmware, so I won't have to bug you later? Same Flasher?
TnEGuy wrote: Fri Nov 07, 2025 3:39 am Man! That link has a lot to absorb. I'll be reading it multiple times.
PM with link sent. Same flasher.
hanslucas
Post by hanslucas »
Would like to get help flashing my drive for UHD discs. Thanks in advance!
Revision: 1.02
Serial number: DGDL027871WL
Highest AACS version: 82
hanslucas wrote: Sat Nov 08, 2025 8:51 pm Would like to get help flashing my drive for UHD discs. Thanks in advance!
Revision: 1.02
PM sent.
iamsirdockalot
Post by iamsirdockalot »
Hi all
Ive got the following drive:
Revision: 1.02
Serial number:
Highest AACS version: 68
And have been trying to read and rip blu ray but freezes while running the most recent version of makeMKV. Reading up suggests its due to copy protections via bad sectors and AACS certifications but trying certified viewers leads to same issues. Further reading got me here but id like to confirm that flashing would fix this issue (with possible benefits of the 4k and UHD) and is the firmware that everyone is asking for to be used with the SDFtool Flasher. If so could I get the firmware needed by the SDFtool since all the other links and forums don’t include the pioneer drives for some reason.
Anything Helps
iamsirdockalot wrote: Thu Nov 13, 2025 5:15 am Hi all
Revision: 1.02
Serial number:
Anything Helps
PM sent. Fixes Libredrive and UHD ripping.
admiralkit
Post by admiralkit »
Hey Coopervid, could you DM me for this? I have a BDV-212V I'd like to flash as well but apparently don't have enough forum karma to DM you.
OS device name: /dev/sr1
Revision: 1.02
Serial number:
admiralkit wrote: Mon Nov 24, 2025 6:37 pm Hey Coopervid, could you DM me for this? I have a BDV-212V I'd like to flash as well but apparently don't have enough forum karma to DM you.
Revision: 1.02
Serial number:
PM sent.
feelideal
Post by feelideal »
Hello, I have the following drive and would like to be able to rip UHD disks.
OS device name: F:
Revision: 1.00
Serial number:
Firmware date: 2020-08-07
Firmware version: 1.00/ID06
feelideal wrote: Mon Dec 01, 2025 3:03 am Hello, I have the following drive and would like to be able to rip UHD disks.
OS device name: F:
Revision: 1.00
Serial number:
PM sent.
jettison55
Post by jettison55 »
Hello. I have the following drive information below. Please PM information to upgrade for UHD reading.
Revision: 1.01
Serial number: BADL
Firmware date: 2021-07-20
Firmware version: 1.01/ID06
jettison55 wrote: Wed Dec 03, 2025 12:56 am Hello. I have the following drive information below. Please PM information to upgrade for UHD reading.
Revision: 1.01
Serial number: BADL
PM sent.
