PM is coming.pkr06 wrote: Tue Nov 11, 2025 2:45 pm Hi Coopervid and everyone,
I recently got an Asus external slim bd drive SBW-06D2X-U and this is the information I get via MakeMKV:
OS device name: J:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: UADL203251WL
Firmware date: 2017-04-18
Firmware version: ID22
I red the forum posts by many and also other topics here. Looks like i need to flash UD04 Fw. But i am not able to find it in the firmwares shared in ultimate flashing guide. (viewtopic.php?f=16&t=19634)
where can i find this firmware ? and can you tell me the steps to flash to read UHD.
Thanks in Advance.
ASUS SBW-06D2X-U
Re: ASUS SBW-06D2X-U
wow.. Great !
This is the new MKV read:
OS device name: J:
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Drive platform: RS8A10
Firmware version: 1.14
Thank you very much Coopervid for your quick response and your time !
OS device name: J:
Revision: 1.14
Serial number:
awconley93
Drive InformationCoopervid wrote: Sat Nov 08, 2025 9:22 pmYou need to post your Makemkv info.awconley93 wrote: Sat Nov 08, 2025 8:36 pmI’m new to ripping and was looking to get the mentioned drive as it’s readily available near me. Can this drive be flashed to rip UHD?Coopervid wrote: Fri Oct 31, 2025 4:20 pm You have to ask Billycar11. My PM was unread for 3 weeks. All unread PMs get deleted after 2 weeks.
OS device name: H:
Manufacturer: ASUS
Revision: A102
Serial number: MZFO37F5844
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
This is a LG based drive and you can flash it with BU40N firmware. Here is the guide:awconley93 wrote: Wed Nov 12, 2025 12:21 pmDrive InformationCoopervid wrote: Sat Nov 08, 2025 9:22 pmYou need to post your Makemkv info.awconley93 wrote: Sat Nov 08, 2025 8:36 pm
OS device name: H:
Manufacturer: ASUS
Revision: A102
awconley93
So I should use the LG flasher or the asus one?Coopervid wrote: Wed Nov 12, 2025 4:08 pmThis is a LG based drive and you can flash it with BU40N firmware. Here is the guide:awconley93 wrote: Wed Nov 12, 2025 12:21 pmDrive Information
OS device name: H:
Manufacturer: ASUS
Revision: A102
If you're on Windows use the SDFtool Flasher: https://forum.makemkv.com/forum/viewtopic.php?f=16&t=22896awconley93 wrote: Thu Nov 13, 2025 1:41 amSo I should use the LG flasher or the asus one?Coopervid wrote: Wed Nov 12, 2025 4:08 pmThis is a LG based drive and you can flash it with BU40N firmware. Here is the guide:awconley93 wrote: Wed Nov 12, 2025 12:21 pm
OS device name: H:
Manufacturer: ASUS
Revision: A102
I have this drive and would like to flash it
OS device name: /dev/sr0
Manufacturer: ASUS
Revision: 1.10
Serial number: <REDACTED>
Highest AACS version: 68
Manufacturer: ASUS
Revision: 1.10
PM sent.CR00K3D wrote: Wed Nov 19, 2025 9:47 pm I have this drive and would like to flash it
Manufacturer: ASUS
Revision: 1.10
Wldulikesometoast
Evening all, I've just picked this drive up. I think it's flashable as it's MT1959 but am hoping for some guidance before I jump in please
Manufacturer: ASUS
Revision: A102
Serial number: MOAO4383618
Highest AACS version: 76
Manufacturer: ASUS
Revision: A102
Follow instructions in guide for bu40n or email me or Marty that drive info section for an auto flasherWldulikesometoast wrote: Sun Nov 23, 2025 8:09 pm Evening all, I've just picked this drive up. I think it's flashable as it's MT1959 but am hoping for some guidance before I jump in please
Manufacturer: ASUS
Revision: A102
Wldulikesometoast
Thanks bro, so the sdf flash tool approach?
Hi All,
I've been spending some time trying to get my external drive to work with Blu-ray, but I’ve discovered the current firmware doesn’t seem to expose BD capabilities correctly.
Drive: ASUS SBW-06D2X-U (Buffalo/ASUS external)
Firmware: Revision 1.10 (2017-04-18)
LibreDrive: Possible, not yet enabled
Kernel mapping: sr1 (scsi3-mmc dvd-ram cd/rw), sg1 type 0
USB bridge: Vendor 0411:55aa (BUFFALO INC.), Mass Storage / SCSI Bulk-Only
System: Linux (CachyOS), MakeMKV v1.18.2
Observed behavior: Drive only reports CD/DVD capabilities under cd-info, MakeMKV hangs with "disc info"
I’d appreciate guidance on whether a patched firmware is available for this revision, and if so, how best to proceed with flashing. Thanks in advance!
Mark
Mark
Post the MakeMKV drive info and libredrive info sections.frankfurt wrote: Wed Nov 26, 2025 3:40 am Hi All,
Mark
Sorry about missing that, here's the output from MakeMKV:
OS device name: /dev/sr1
Manufacturer: ASUS
Revision: 1.10
Serial number: ALDL242666WL
Manufacturer: ASUS
Revision: 1.10
