Mikeuk2025
Post by Mikeuk2025 »
Hi , just ordered a ugoos for FEL playback
Is it just as simple as ripping a 4k disc using makemkv ??? Or do i need to do anything else ? , also looking at the excel spread sheet it says FEL playback is suported from iso and folder **Unwanted Spam** so again is it just as simple as ripping it to folder format ??
Yes, the Ugoos supports every format, but the best and most stable one is MKV, of course.
Mikeuk2025
RESET_9999 wrote: Wed Oct 29, 2025 2:08 pm Yes, the Ugoos supports every format, but the best and most stable one is MKV, of course.
ok thanks
MastaG
Post by MastaG »
Just tried that VS10 engine on a few SDR movies and I must say it really makes them shine.
For example the movie Elio (2025) in fullhd sdr really shines when enabling the VS10 to DV engine. The colors really pop from the screen.
I've also tried two FEL movies.
13 hours secret soldiers of benghazi: This one looks pretty nice.
Avatar 2: This one was a little underwhelming.
I have to try out more, but FEL DV being rendered into 12bits if I'm not mistaken isn't necessarily better then MEL.
It really depends on the mastering of the movie.
MastaG wrote: Thu Oct 30, 2025 7:12 pm I have to try out more, but FEL DV being rendered into 12bits if I'm not mistaken isn't necessarily better then MEL.
FEL in some movies adds nothing, but there are a few that expand the brightness much higher and TVs like the G5 benefit the most from it.
see my youtube video about it: https://www.youtube.com/watch?v=MnZVk1eNMZs
I made a sample of the ones that expand brightness. These don’t show the difference between FEL and HDR10, they show the difference between playing FEL on a device that can decode it and one that can’t.
https://drive.google.com/drive/u/0/fold ... ziCe_R_IKe
staknhalo
Post by staknhalo »
Now we have HDR10+ Advanced too 🙃
https://www.youtube.com/watch?v=9bfUXHUy7pU
Post by SamuriHL »
They really want hdr10+ to be a thing. Lol
Trees
Post by Trees »
Is it possible to compare tonemapped P5 screenshots with P8?
Reason I ask is because as of lately I'm seeing more and more "RGB 16-bit" screenshots floating around. Are these accurate representation of what P5 has to offer? I thought it was only possible to compare the two by taking pictures of the TV? If so, how are these RGB screenshots made?
with libplacebo, nothing new...
workflow 7-2 in dovi_scripts
Trees
Post by Trees »
RESET_9999 wrote: Tue Nov 11, 2025 12:22 am with libplacebo, nothing new...
Interesting.
Assuming HDR10 is HDR and Profile 5 DV is "expanded HDR" (effectively 12-bit colours because of how the master-to-P5 conversion works), are these tonemapped screenshots an acccurate representation of P5? Am I correct in thinking there's no point comparing them on a regular 8-bit, regular 10-bit screen (HDR) without the capability of "expanded HDR" (P5)? If you know what I mean?
DV is HDR. HDR is a general term that encompasses all HDR formats: HDR10, Dolby Vision, HLG, and HDR10+.
There’s no visible difference unless the grading itself differs, or if the WEB-DL comes from Apple TV because Apple is stupid, applies the same color reshaping metadata to all content, which slightly distorts the colors. This issue has nothing to do with P5 using 10bit ICtCp that effectively equivalent to 11.5-bit YCbCr. When comparing P5 and HDR10 across Disney+, Amazon, Netflix, or MAX, they will always look identical, even when viewed in 16-bit RGB.
example, Frankenstein 2025: https://slow.pics/c/u84fKFsI
more examples here:
https://docs.google.com/spreadsheets/d/ ... 1226038728
Trees
Post by Trees »
RESET_9999 wrote: Tue Nov 11, 2025 12:11 pmWhen comparing P5 and HDR10 across Disney+, Amazon, Netflix, or MAX, they will always look identical, even when viewed in 16-bit RGB.
Thanks, I think this clears it up for me. In other words, P5 and HDR10 comparisons need to be done on TVs in order to see the the difference in colours, correct?
RESET_9999 wrote: Tue Nov 11, 2025 12:11 pmexample, Frankenstein 2025: https://slow.pics/c/u84fKFsI
What I'm seeing here is just a difference in quality (blocking and compression artifacts etc.), no difference in HDR quality possible, correct?
Trees
Post by Trees »
I finally got a Ugoos AM6B+ (yes, for christmas)!
For clarity sake, is CoreELEC-Amlogic-ng.arm-21.3-Omega-Generic.img.gz still the version to get or is there a newer version available?
I'm asking because the CoreElec website mentions a update, v22.
Post by SamuriHL »
You can install that to get CoreELEC installed but then I would use this:
https://github.com/avdvplus/Builds/rele ... vdvplus_R3
Basically once you get CoreELEC installed, you put that tar file in the update folder, reboot, and then check the settings, CoreELEC menu to setup your Dolby Vision options for your particular environment.
This is only my recommendation.
Trees
Post by Trees »
Thank you for the recommendation.
Where can I read up on information on the features of this update?
