Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
I came across these Verbatim drives on the shelf at a local store. Is it still possible they have Pioneers drives in them?
Not unless they have had it on the shelf for a year+.
RoyBoy_TLV
Hi, I have a Verbatim External Slimline Blu-ray Writer #43890 drive at home and was wondering if it can work with LibreDrive and read UHD.
Here is some Info:
OS device name: T:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 65
Drive platform: RS8511
Firmware version: 1.14
Here is some Info:
OS device name: T:
Revision: 1.14
Serial number:
PM sent.RoyBoy_TLV wrote: ↑Tue Nov 11, 2025 4:35 amHi, I have a Verbatim External Slimline Blu-ray Writer #43890 drive at home and was wondering if it can work with LibreDrive and read UHD.
Here is some Info:
OS device name: T:
Revision: 1.14
Serial number:
To give an update, the 43889 that I received contained the usual BU40N. The drive info below is after following the flashing guide and using the correct image from the all you need pack using the GUI on Windows.
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.03
Serial number:
Highest AACS version: 76
Firmware version: 1.03
so I decided to roll the dice and went back to the store. the store had a decent return policy on hardware, and lucked out:
OS device name: /dev/sr1
Revision: 1.14
Serial number: CIDL50****WL
PM sent.203onroof wrote: ↑Tue Nov 11, 2025 8:10 pmso I decided to roll the dice and went back to the store. the store had a decent return policy on hardware, and lucked out:can I please get the info on how to enable UHD read on this drive?Code: Select all
Drive Information OS device name: /dev/sr1 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: CIDL50****WL Firmware date: 2020-06-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
I have a Verbatim 43890 mechanism and I need firmware to support UHD Blu-ray. Can you help me?
OS device name: E:
Revision: 1.11
Serial number: ------------
Firmware date: 2018-11-28
Highest AACS version: 81
Firmware version: 1.11
No disc insertedRe: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
PM sent.kofwae wrote: ↑Thu Nov 13, 2025 5:27 pmCode: Select all
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.11 Serial number: ------------ Firmware date: 2018-11-28 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.11 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
gundelpfanne
Hello i have a Problem with my BDR Pioneer.
Laufwerksinformation
OS-Gerätename: L:
Aktuelles Profil: DVD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.11
Serienummer:
Firmware-Datum: 2018-11-28
Keine Disk eingelegt
Can i have the modded Firmware.
Thank You
mfg gundelpfanne
OS-Gerätename: L:
Produzent: PIONEER
Revision: 1.11
Serienummer:
Thank You
mfg gundelpfanne
