Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
amhome
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Post by amhome » Mon Nov 10, 2025 3:37 am
Coopervid wrote: Sun Nov 09, 2025 10:53 am
amhome wrote: Sat Nov 08, 2025 10:53 pm @CooperVid or whomever else is able to work with this drive - Thank you in advance.
I have two drives I wish to have UHD enabled for.
PM sent.
Worked Great! Drive is reading UHD now. Thank you.
203onroof
Post by 203onroof » Mon Nov 10, 2025 8:18 pm
I came across these Verbatim drives on the shelf at a local store. Is it still possible they have Pioneers drives in them?
Post by Coopervid » Mon Nov 10, 2025 10:47 pm
203onroof wrote: Mon Nov 10, 2025 8:18 pm I came across these Verbatim drives on the shelf at a local store. Is it still possible they have Pioneers drives in them?
Most likely not.
Post by MartyMcNuts » Mon Nov 10, 2025 11:00 pm
Not unless they have had it on the shelf for a year+.
RoyBoy_TLV
Post by RoyBoy_TLV » Tue Nov 11, 2025 4:35 am
Hi, I have a Verbatim External Slimline Blu-ray Writer #43890 drive at home and was wondering if it can work with LibreDrive and read UHD.
Here is some Info:
OS device name: T:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 65
Drive platform: RS8511
Firmware version: 1.14
Post by Coopervid » Tue Nov 11, 2025 11:12 am
RoyBoy_TLV wrote: Tue Nov 11, 2025 4:35 am Hi, I have a Verbatim External Slimline Blu-ray Writer #43890 drive at home and was wondering if it can work with LibreDrive and read UHD.
Here is some Info:
OS device name: T:
Revision: 1.14
Serial number:
PM sent.
sappy
Post by sappy » Tue Nov 11, 2025 3:39 pm
sappy wrote: Fri Nov 07, 2025 4:54 pm I mistakenly ordered a 43889, and I have a 43888 on the way. But I heard that it might be possible to rip UHD with an 43889 anyway? Not sure which drives are in them yet.
To give an update, the 43889 that I received contained the usual BU40N. The drive info below is after following the flashing guide and using the correct image from the all you need pack using the GUI on Windows.
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.03
Serial number:
Highest AACS version: 76
Firmware version: 1.03
Regular blu-rays and DVDs worked fine. When I tried a UHD Dune disk it did not work initially. But after loading the latest sdf.bin it worked flawlessly. Would recommend!
203onroof
Post by 203onroof » Tue Nov 11, 2025 8:10 pm
Coopervid wrote: Mon Nov 10, 2025 10:47 pm
Most likely not.
so I decided to roll the dice and went back to the store. the store had a decent return policy on hardware, and lucked out:
OS device name: /dev/sr1
Revision: 1.14
Serial number: CIDL50****WL
can I please get the info on how to enable UHD read on this drive?
Post by Coopervid » Wed Nov 12, 2025 10:13 am
203onroof wrote: Tue Nov 11, 2025 8:10 pm
Most likely not.
Revision: 1.14
PM sent.
203onroof
Post by 203onroof » Wed Nov 12, 2025 10:00 pm
Coopervid wrote: Wed Nov 12, 2025 10:13 am PM sent.
Thank you! I can't reply in PM (guessing I'm too new). I was able to flash the drive.
kofwae
Post by kofwae » Thu Nov 13, 2025 10:12 am
I have a Verbatim 43890 mechanism and I need firmware to support UHD Blu-ray. Can you help me?
Post by Coopervid » Thu Nov 13, 2025 5:04 pm
kofwae wrote: Thu Nov 13, 2025 10:12 am I have a Verbatim 43890 mechanism and I need firmware to support UHD Blu-ray. Can you help me?
You need to post your Makemkv info.
kofwae
Post by kofwae » Thu Nov 13, 2025 5:27 pm
OS device name: E:
Revision: 1.11
Serial number: ------------
Firmware date: 2018-11-28
Highest AACS version: 81
Firmware version: 1.11
Post by Coopervid » Sat Nov 15, 2025 11:30 am
kofwae wrote: Thu Nov 13, 2025 5:27 pm
OS device name: E:
Revision: 1.11
PM sent.
gundelpfanne
Post by gundelpfanne » Sun Nov 16, 2025 10:58 am
Hello i have a Problem with my BDR Pioneer.
Laufwerksinformation
OS-Gerätename: L:
Aktuelles Profil: DVD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.11
Serienummer:
Firmware-Datum: 2018-11-28
Keine Disk eingelegt
Can i have the modded Firmware.
Thank You
mfg gundelpfanne
