LibreDrive for Pioneer drives
I just saw that your drive has 2023 firmware. So you can't flash. Sorry that I missed that.
TheGame21x
Hmm, that's odd then. I can try running the flasher again but I'm still not sure what went wrong.nicholfd wrote: Fri Nov 07, 2025 9:50 pmI don't think he was indicating a VM improves the process - just that if you are using a VM, the settings of the virtualization app/virtual machine may cause issues.TheGame21x wrote: Fri Nov 07, 2025 9:45 pm
Yes, I'm on Windows 10. I can try using VMWare. the firmware I received was for the BDR-211, will that work for my 209M drive? Thanks for the help!
I exclusively use macOS as my primary computer OS. I have never had a failure with MakeMKV/flashing tools in Windows 10 & 11 VMs, on UTM (Free/Open Source), vmWare Fusion & Parallels. Due to licensing & what I own, I often switch between Win 10/11 VMs on all three virtualization apps, when working with/flashing optical drives that require Windows.
Thanks,
Frank
TheGame21x
Oh, damn. I thought I saw an update that allowed me to flash on 1.55 firmware but I guess not. Thanks anyway. I'll keep waiting.Coopervid wrote: Fri Nov 07, 2025 10:12 pm I just saw that your drive has 2023 firmware. So you can't flash. Sorry that I missed that.
Locmo
Can this Pio drive be flashed for 4k discs ? Thanks
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.30
Serial number: xxxx
Firmware date: 2014-12-05
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8600
Firmware version: 1.30/ID61
OS device name: E:
Revision: 1.30
Serial number: xxxx
PM sent.Locmo wrote: Sun Nov 09, 2025 3:43 pm Can this Pio drive be flashed for 4k discs ? Thanks
OS device name: E:
Revision: 1.30
Serial number: xxxx
spike75aa
Would it be possible to flash this drive to support UHD disks with MakeMKV?
OS device name: /dev/rdisk5
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Serial number: CCDL267062WL
Firmware date: 2018-08-22
Highest AACS version: 57
Drive platform: RS8511
Firmware version: E101/ID26
No disc inserted-
PM sent.spike75aa wrote: Mon Nov 10, 2025 12:37 pm Would it be possible to flash this drive to support UHD disks with MakeMKV?
Drive Information OS device name: /dev/rdisk5 Current profile: BD-ROM Manufacturer: ASUS Product: SBW-06D5H-U Revision: E101 Serial number: CCDL267062WL Firmware date: 2018-08-22 Bus encryption flags: 1B Highest AACS version: 57 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: E101/ID26 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
REbornDArth
I got the same drive actually and it just so happens to have locked me out...Coopervid wrote: Mon Nov 10, 2025 3:08 pmPM sent.spike75aa wrote: Mon Nov 10, 2025 12:37 pm Would it be possible to flash this drive to support UHD disks with MakeMKV?
PM sent.REbornDArth wrote: Tue Nov 11, 2025 1:39 pmI got the same drive actually and it just so happens to have locked me out...Coopervid wrote: Mon Nov 10, 2025 3:08 pmPM sent.spike75aa wrote: Mon Nov 10, 2025 12:37 pm Would it be possible to flash this drive to support UHD disks with MakeMKV?
REbornDArth
thanks so much, sadly the drive is not accepting the firmware for some odd reason.Coopervid wrote: Tue Nov 11, 2025 2:43 pmPM sent.REbornDArth wrote: Tue Nov 11, 2025 1:39 pmI got the same drive actually and it just so happens to have locked me out...
Here my drive info
Laufwerksinformation
OS-Gerätename: E:
Produzent: ASUS
Produkt: SBW-06D5H-U
Revision: E102
Serienummer: CJDL280696WL
Firmware-Datum: 2023-04-20
Highest AACS version: 46
Firmware version: E102/ID26
You had said you have the SAME drive. You don't and usually I ask for a post of Makemkv info. I didn't. Your drive has past Dec. 2022 firmware and is currently not flashable. You have to wait if and when Mike comes up with a solution.REbornDArth wrote: Tue Nov 11, 2025 4:37 pmthanks so much, sadly the drive is not accepting the firmware for some odd reason.Coopervid wrote: Tue Nov 11, 2025 2:43 pmPM sent.REbornDArth wrote: Tue Nov 11, 2025 1:39 pm
Here my drive infoIt seems to be the same drive, but a newer model. I just get the message: "Kernel not sent"Code: Select all
Laufwerksinformation OS-Gerätename: E: Produzent: ASUS Produkt: SBW-06D5H-U Revision: E102 Serienummer: CJDL280696WL Firmware-Datum: 2023-04-20 Markierungen der Bus-Verschlüsselung: 1B Highest AACS version: 46 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: E102/ID26 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
REbornDArth
Thanks for letting me know. Then I'll wait. Meanwhile I ordered another drive that should have better support.Coopervid wrote: Tue Nov 11, 2025 4:48 pm You had said you have the SAME drive. You don't and usually I ask for a post of Makemkv info. I didn't. Your drive has past Dec. 2022 firmware and is currently not flashable. You have to wait if and when Mike comes up with a solution.
Finray
Hi can someone please help me activate Libredrive and UHD (if possible) with the following drive. The manufacture date says 2024.
Product: BD-RW BDR-209MIO
Revision: 1.30
Serial number: QGDL*******
Firmware date: 2015-10-30
Highest AACS version: 61
Drive platform: Pioneer RS8600
Firmware version: ID13
Revision: 1.30
PM sent.Finray wrote: Thu Nov 13, 2025 9:29 am Hi can someone please help me activate Libredrive and UHD (if possible) with the following drive. The manufacture date says 2024.
Revision: 1.30
Lbrtydrmr
OS device name: E:
Revision: 1.51
Serial number: SGDL054873WL
Firmware date: 2018-05-08
Highest AACS version: 76
Drive platform: RS8601
Firmware version: 1.51/ID61
OS device name: E:
Revision: 1.51
