sdftool never ends
mirto
sdftool never ends
#1 Post by mirto » Wed Nov 05, 2025 11:37 am
Hi all,
I'm trying to flash LibreDrive on an LG BD-RE BH16NS55 drive
After reading a lot of posts and tutorials I ended up with this command (that I launched as normal user and as root with same result)
sdftool -v -d /dev/sr0 flash -i HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
But the command uses 100% of CPU and never ends
    /DATA-1/nfs-/MANU/D/D/The all you need firmware pack/LG 5.25 desktop  ls -lh         ✔
totale 2,0M
-rw-r--r-- 1 mirto mirto 2,0M 31 ago  2019 HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
    /DATA-1/nfs-/MANU/D/D/The all you need firmware pack/LG 5.25 desktop  sdftool -v -d /dev/sr0 flash -i HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin         ✔
Loaded SDF.bin version 0x98
^C
    /DATA-1/nfs-/MANU/D/D/The all you need firmware pack/LG 5.25 desktop          INT ✘  4m
What can I do to flash the firnìmware in the drive?
Programs versions and info:
from kakemkv
OS device name: /dev/sr0
Product: BD-RE BH16NS55
Revision: 1.05
Serial number: KLFL1BJ2441
Firmware date: 2120-06-18 13:42
Highest AACS version: 68
Log
MakeMKV v1.18.2 linux(x64-release) started
Downloading latest SDF to /home/mirto/.MakeMKV ...
Automatic SDF downloading is disabled or failed.
I'm using MakeMKV on Manjaro using the AUR package that includes the sdftool
    ~  pamac info makemkv         ✔
Nome                          : makemkv
Versione                      : 1.18.2-1
Descrizione                   : DVD and Blu-ray to MKV converter
URL                           : https://www.makemkv.com
Licenze                       : LicenseRef-GuinpinSoft-inc-EULA LGPL-2.1-or-later
Repository                    : AUR
Dimensione installato         : 44,1 MB
Gruppi                        : --
Dipendenze necessarie         : qt5-base ffmpeg libavcodec.so
Dipendenze opzionali          : java-runtime: bdjava https://www.makemkv.com/bdjava/ [Installati]
Dipendenze per la costruzione : --
Controlla le dipendenze       : --
Dipendenza necessaria per     : --
Dipendenza opzionale per      : --
Fornisce                      : --
Sostituisce                   : --
In conflitto con              : --
Packager                      : Unknown Packager
Manutentore                   : FabioLolix
Primo invio                   : mar 26 gen 2010, 16:31:24
Ultima modifica               : lun 29 set 2025, 07:03:33
Voti                          : 337
Obsoleto                      : --
Data di creazione             : mer 1 ott 2025, 10:43:00
Data installazione            : mer 1 ott 2025, 10:43:47
Motivo della installazione    : Esplicitamente installato
Convalidato da                : Nessuno
File salvati                  : --
Re: sdftool never ends
#2 Post by dcoke22 » Sat Nov 08, 2025 2:58 pm
Some folks have had luck going back to MakeMKV 1.17.7. https://forum.makemkv.com/forum/viewtopic.php?f=3&t=37670
mirto
#3 Post by mirto » Sun Nov 09, 2025 8:34 am
Thanks I'll try.
mirto
#4 Post by mirto » Sun Nov 09, 2025 9:03 pm
SOLVED
I needed two commands: “rawflash enc
The working command is
sudo sdftool -v -d /dev/sr0 rawflash enc -i HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
