[SOLVED] BDR-S06XLB (2011) NOT UHD compatible
guanciale!
Post by guanciale! »
Looking for another Pioneer purchase... 8)
I found a 2011 one... Before buying it I'd like to know if it compatible and can be flashed to enable UHD.
Here's a picture of its label:
:twisted: cook until you are hungry :twisted:
Re: Pioneer BDR-S06XLB (2011 manufactured)
guanciale! wrote: Sun Nov 09, 2025 8:11 am Looking for another Pioneer purchase... 8)
There’s no attachment. Copy and paste the drive info and libredrive info sections so we can have a look but being that old, I think you might be out of luck.
guanciale!
Hello MartyMcNuts !! 8)
That's the only info I could get from the seller.
He is not a technical person, and the drive has been removed and he no longer has a PC to connect it to, sadly...
guanciale! wrote: Sun Nov 09, 2025 8:23 am Hello MartyMcNuts !! 8)
That means nothing. We would need to see the drive platform info from MakeMKV but I'm 99% sure that this drive can't be made UHD compatible, even if libredrive can be enabled on it. I think it is the 208 / S08 models and above (with firmware pre 12/2022) that can be made UHD capable.
guanciale!
MartyMcNuts wrote: Sun Nov 09, 2025 9:42 am
OK, understood.
( I'll try to come to an agreement with the seller: if they settle for a reasonable -- for me -- price, or if they whatever decide to accept a possible return or refund, I might buy it... :idea: )
guanciale! wrote: Sun Nov 09, 2025 9:55 am
OK, understood.
No point. As I said, I am 99% certain that this drive will never be able to read UHD discs.
S06 can't be made UHD capable. 100% sure.
guanciale!
Coopervid wrote: Sun Nov 09, 2025 10:41 am S06 can't be made UHD capable. 100% sure.
Oh... That's sad! :(
Anyway, thank you for confirming that, you saved me from making a useless purchase! :wink:
guanciale! wrote: Sun Nov 09, 2025 2:47 pm
Why change the title to "Unsolvable"?? It is 100% solved. The drive cannot be made UHD compatible.
