Question re License terms
seamus
Post by seamus »
I'm considering buying a license for MakeMKV. However, I've been unable to find any document or documentation that describes the license terms.
Does anyone know where the license terms for MakeMKV can be found??
Thnx,
~S
Re: Question re License terms
I've seen it mentioned on the forum, but I haven't seen an official document. In summary, the software is licensed to you, not to a specific install. You can run it on all the computers you own. One license works for multiple operating systems as well.
Mike has always been sparing with details on the license. It IS part of the start-up for the program during the install, with the opportunity to print it out. You can see it while running the installer, before it gets to writing programs to the drive.
As for the question of "how many copies can you run?", Mike answered that in a rather simple message back in 2020:
mike admin wrote: Mon Jun 29, 2020 9:47 pm
henrikn wrote: Mon Jun 29, 2020 6:39 pm The thing is, I am using a Windows desktop or my Macbook laptop (with an external DVD drive, which I use on both computers). Will I be able to use the same license key, to both computers?
Yes.
