AACS V82 Slash
DannyParker
AACS V82 Slash
Post by DannyParker »
Hi First time poster and first time encountering this issue. I just bought the new live Slash blu ray and am having trouble ripping it. The is the dump file. Any help would be swell.
Re: AACS V82 Slash
DannyParker wrote: Fri Nov 07, 2025 8:57 pm Hi First time poster and first time encountering this issue. I just bought the new live Slash blu ray and am having trouble ripping it. The is the dump file. Any help would be swell.
Please email the dump file to svq@makemkv.com.
If you want to contribute to the public keydb, read the first post in this thread: Public KeyDB Disc Submissions
DannyParker
Re: AACS V82 Slash
Please explain it to me like I'm an idiot. I use Make MKV, I'm not an expert at it. Thanks
Re: AACS V82 Slash
DannyParker wrote: Fri Nov 07, 2025 9:07 pm Please explain it to me like I'm an idiot. I use Make MKV, I'm not an expert at it. Thanks
I presume you're confused about what to do with the dump file MakeMKV produced and how it relates to eventually being able to rip your disc. I wrote a more detailed post here: https://forum.makemkv.com/forum/viewtopic.php?p=186497#p186497
DannyParker
Re: AACS V82 Slash
I'm sorry. None of that made any sense to me. You told what to do but not how to do it.
Re: AACS V82 Slash
DannyParker wrote: Fri Nov 07, 2025 9:28 pm I'm sorry. None of that made any sense to me. You told what to do but not how to do it.
Attach the dump file to an email and send it to svq@makemkv.com. Unless you can be more detailed about where you're getting stuck, I don't know how to be more clear.
DannyParker
Re: AACS V82 Slash
I've done that. I don't understand adding it to a list, checking said list or what to do once that's done.
Re: AACS V82 Slash
If you've emailed it, in a few days a hashed key will likely be available and all you have to do is try to rip your disc again. If a key is available MakeMKV will download it and let you rip the disc. Unfortunately you can't know how long it'll take for a hashed key to be made.
If you don't want to try using the public keydb you don't have to. It is optional, but there might already be a key for your disc in the keydb. If not, if you contribute your dump file a key will likely be added relatively quickly, often faster than the key mechanism built into MakeMKV.
DannyParker
Re: AACS V82 Slash
I simpy don't know how to use the keyDB. I downloaded the database but Couldn't open it. Just tried backing it up again and still doesn't work
howipp3@gmail.com
Re: AACS V82 Slash
Post by howipp3@gmail.com »
Hi there
I have the same issue with Wings and Who Are You.
I cannot attach the winrar file which I think is the dump file.
MKB_V81_save.tgz and
MKB_V82_save.tgz
So I created .rar files and have uploaded them
Also please advise exactly where to save the keydb.cfg file whhich I downloaded from http://fvonline-db.bplaced.net.
Here is a jpg of that directory.
I place it in the directory .Makemkv.
But still no success.
I am hoping for a MakeMkv update.....
Howard
Re: AACS V82 Slash
DannyParker wrote: Mon Nov 10, 2025 8:03 pm I simpy don't know how to use the keyDB. I downloaded the database but Couldn't open it. Just tried backing it up again and still doesn't work
The file you downloaded should've been a .zip file. Inside that zip file should be one big text file.
howipp3@gmail.com wrote: Tue Nov 11, 2025 1:11 am
The file goes in the MakeMKV data directory. Look on the General tab of MakeMKV's preferences to see where that directory is. Restart MakeMKV after putting the file in the right place.
