Hello, I have a Pioneer BD-RW BDR-XS07U
Drive information
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: CIDL007887WL
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 82
LibreDrive information
Drive platform: RS8E21
Firmware version: 1.03/ID05
As you can see from the drive information, it should now at least support Blu-rays (and I also had the faint hope that it could handle UHD). Unfortunately, nothing happens at all. It can rip DVDs, but that's it...
My question is, how likely is it that it is defective, or are there other ways to get it working?
Translated with DeepL.com (free version)
Pioneer BD-RW BDR-XS07U does not work.
zittrig
Re: Pioneer BD-RW BDR-XS07U does not work.
Blu-rays and 4K won't recognize at all?
Perhaps the blue laser is defective or dirty.
You can try to clean the laser lenses with alcohol and q-tips. Clean and dry without getting the alcohol on the laser dry by air.
Artefakt
Thank you very much, that's it. I bought the drive on eBay a year ago. Because of the new firmware, I thought I would have to wait until Mike had a solution ready. Then the solution came and the drive still didn't work.zittrig wrote: Sat Nov 08, 2025 1:22 pm
When I got it back then, it smelled so bad of nicotine that it made me feel sick (I suspect that was the problem).
I quickly researched how to clean the laser head online, and now it works and even rips UHD discs.
zittrig
You're welcome. Enjoy it.
