LibreDrive for Pioneer drives
I just saw that your drive has 2023 firmware. So you can't flash. Sorry that I missed that.
TheGame21x
Post by TheGame21x »
nicholfd wrote: Fri Nov 07, 2025 9:50 pm
TheGame21x wrote: Fri Nov 07, 2025 9:45 pm
Yes, I'm on Windows 10. I can try using VMWare. the firmware I received was for the BDR-211, will that work for my 209M drive? Thanks for the help!
I don't think he was indicating a VM improves the process - just that if you are using a VM, the settings of the virtualization app/virtual machine may cause issues.
I exclusively use macOS as my primary computer OS. I have never had a failure with MakeMKV/flashing tools in Windows 10 & 11 VMs, on UTM (Free/Open Source), vmWare Fusion & Parallels. Due to licensing & what I own, I often switch between Win 10/11 VMs on all three virtualization apps, when working with/flashing optical drives that require Windows.
Thanks,
Frank
Hmm, that's odd then. I can try running the flasher again but I'm still not sure what went wrong.
TheGame21x
Coopervid wrote: Fri Nov 07, 2025 10:12 pm I just saw that your drive has 2023 firmware. So you can't flash. Sorry that I missed that.
Oh, damn. I thought I saw an update that allowed me to flash on 1.55 firmware but I guess not. Thanks anyway. I'll keep waiting.
Locmo
Post by Locmo »
Can this Pio drive be flashed for 4k discs ? Thanks
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.30
Serial number: xxxx
Firmware date: 2014-12-05
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8600
Firmware version: 1.30/ID61
Locmo wrote: Sun Nov 09, 2025 3:43 pm Can this Pio drive be flashed for 4k discs ? Thanks
OS device name: E:
Revision: 1.30
Serial number: xxxx
PM sent.
spike75aa
Post by spike75aa »
Would it be possible to flash this drive to support UHD disks with MakeMKV?
OS device name: /dev/rdisk5
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Serial number: CCDL267062WL
Firmware date: 2018-08-22
Highest AACS version: 57
Drive platform: RS8511
Firmware version: E101/ID26
spike75aa wrote: Mon Nov 10, 2025 12:37 pm Would it be possible to flash this drive to support UHD disks with MakeMKV?
Manufacturer: ASUS
Revision: E101
PM sent.
REbornDArth
Post by REbornDArth »
Coopervid wrote: Mon Nov 10, 2025 3:08 pm
Manufacturer: ASUS
Revision: E101
PM sent.
I got the same drive actually and it just so happens to have locked me out...
REbornDArth wrote: Tue Nov 11, 2025 1:39 pm
Manufacturer: ASUS
Revision: E101
PM sent.
PM sent.
REbornDArth
Coopervid wrote: Tue Nov 11, 2025 2:43 pm
PM sent.
PM sent.
thanks so much, sadly the drive is not accepting the firmware for some odd reason.
Here my drive info
Laufwerksinformation
OS-Gerätename: E:
Produzent: ASUS
Produkt: SBW-06D5H-U
Revision: E102
Serienummer: CJDL280696WL
Firmware-Datum: 2023-04-20
Highest AACS version: 46
Firmware version: E102/ID26
It seems to be the same drive, but a newer model. I just get the message: "Kernel not sent"
REbornDArth wrote: Tue Nov 11, 2025 4:37 pm
PM sent.
Here my drive info
OS-Gerätename: E:
Produzent: ASUS
Revision: E102
You had said you have the SAME drive. You don't and usually I ask for a post of Makemkv info. I didn't. Your drive has past Dec. 2022 firmware and is currently not flashable. You have to wait if and when Mike comes up with a solution.
REbornDArth
Coopervid wrote: Tue Nov 11, 2025 4:48 pm You had said you have the SAME drive. You don't and usually I ask for a post of Makemkv info. I didn't. Your drive has past Dec. 2022 firmware and is currently not flashable. You have to wait if and when Mike comes up with a solution.
Thanks for letting me know. Then I'll wait. Meanwhile I ordered another drive that should have better support.
Finray
Post by Finray »
Hi can someone please help me activate Libredrive and UHD (if possible) with the following drive. The manufacture date says 2024.
Product: BD-RW BDR-209MIO
Revision: 1.30
Serial number: QGDL*******
Firmware date: 2015-10-30
Highest AACS version: 61
Drive platform: Pioneer RS8600
Firmware version: ID13
Finray wrote: Thu Nov 13, 2025 9:29 am Hi can someone please help me activate Libredrive and UHD (if possible) with the following drive. The manufacture date says 2024.
Revision: 1.30
PM sent.
Lbrtydrmr
Post by Lbrtydrmr »
OS device name: E:
Revision: 1.51
Serial number: SGDL054873WL
Firmware date: 2018-05-08
Highest AACS version: 76
Drive platform: RS8601
Firmware version: 1.51/ID61
