Here's my drive info:
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.02
Serial number: CFDL******UC
Firmware date: 2022-12-27
Drive platform: Pioneer RS9330
Firmware version: GENE
I understand It may still be possible to unlock this drive. Any info would be great, thanks!
LibreDrive for Pioneer drives
Not yet as firmware is post 11/2022 but I hear libredrive support is coming pretty soon! That doesn't mean it will do UHD though. Not sure if they will be able to be cross-flashed with MakeMKV's SDFtool. We will have to wait and see.Arkus wrote: Sun Nov 02, 2025 9:43 pm Here's my drive info:
Revision: 1.02
larhaus
Sadly, it seems that you are correct. I put a triple-layer UHD BD in, and it attempts to read for a minute and gives up with "no disc".MartyMcNuts wrote: Mon Nov 03, 2025 3:53 amNot yet as firmware is post 11/2022 but I hear libredrive support is coming pretty soon! That doesn't mean it will do UHD though. Not sure if they will be able to be cross-flashed with MakeMKV's SDFtool. We will have to wait and see.Arkus wrote: Sun Nov 02, 2025 9:43 pm Here's my drive info:
Revision: 1.02
OS device name: O:
Revision: 1.02
Serial number: DDDL******UC
Highest AACS version: 81
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02
scav666
I bought another drive and would like to make it capable of reading UHD discs. Could you please help me get the flasher?
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: removed
Firmware date: 2020-07-21
Highest AACS version: 77
Drive platform: RS8F00
Firmware version: E116/ID71
PM sent.scav666 wrote: Wed Nov 05, 2025 9:02 pm I bought another drive and would like to make it capable of reading UHD discs. Could you please help me get the flasher?
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
alexander_ac
I've just updated MakeMKV and its SDF.bin but I still can't read HDBD's. Is this still a work in progress?
Product: BD-RW BDR-S12U
Revision: 1.05
Serial number:
Firmware date: 2023-08-01
Highest AACS version: 72
Drive platform: RS8F01
Firmware version: 1.05/ID43
Disc Information
Label: JWFK_UPK1
Timestamp: 2018-08-03 15:25:20
Protection: AACS2.0/C v65
Data capacity: 5509.3 Gb
Bus encryption flags: 80
MakeMKV v1.18.2 win(x64-release) started
Using LibreDrive mode (v02.2 id=91ED53B2A9BB)
Downloading latest HK to C:\Users\Alexander/.MakeMKV ...
Saved AACS dump file as C:\Users\Alexander/.MakeMKV/MKB20_v65_Jurassic_World-_Fallen_Kingdom_C48F.tgz
Revision: 1.05
Serial number:
Disc Information
Label: JWFK_UPK1
Send this dump, it looks like this particular disc is not enabled.alexander_ac wrote: Thu Nov 06, 2025 12:09 am Saved AACS dump file as C:\Users\Alexander/.MakeMKV/MKB20_v65_Jurassic_World-_Fallen_Kingdom_C48F.tgz
alexander_ac
Here it is https://1drv.ms/u/c/d6f3cb9a7436a080/Ef ... A?e=5iy15amike admin wrote: Thu Nov 06, 2025 9:19 amSend this dump, it looks like this particular disc is not enabled.alexander_ac wrote: Thu Nov 06, 2025 12:09 am Saved AACS dump file as C:\Users\Alexander/.MakeMKV/MKB20_v65_Jurassic_World-_Fallen_Kingdom_C48F.tgz
nicholfd
Hello!alexander_ac wrote: Fri Nov 07, 2025 12:50 amHere it is https://1drv.ms/u/c/d6f3cb9a7436a080/Ef ... A?e=5iy15amike admin wrote: Thu Nov 06, 2025 9:19 amSend this dump, it looks like this particular disc is not enabled.alexander_ac wrote: Thu Nov 06, 2025 12:09 am Saved AACS dump file as C:\Users\Alexander/.MakeMKV/MKB20_v65_Jurassic_World-_Fallen_Kingdom_C48F.tgz
Please send the dump to this e-mail address; svq@makemkv.com
For sale 4K UHD Flashed USB drives:
ASUS Slim, Buffalo Slim, LG Slim,
Buffalo 5 1/4", ASUS 5 1/4",
drives@nicholasfamilycentral.com
TheGame21x
I'm seeing that there was an update to the libredrive support for Pioneer drives? Does that mean I would be able to flash my BDR-209M drive to enable Libredrive on firmware 1.55? Attached the MakeMKV information below.
OS device name: E:
Product: BD-RW BDR-209M
Revision: 1.55
Serial number: NEDL003640WL
Firmware date: 2023-02-16
Bus encryption flags: 13
Highest AACS version: 70
Drive platform: RS8600
Firmware version: 1.55/ID60
Libredrive is enabled but no UHD ripping. Check your PM.TheGame21x wrote: Fri Nov 07, 2025 7:38 pm I'm seeing that there was an update to the libredrive support for Pioneer drives? Does that mean I would be able to flash my BDR-209M drive to enable Libredrive on firmware 1.55? Attached the MakeMKV information below.
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-209M Revision: 1.55 Serial number: NEDL003640WL Firmware date: 2023-02-16 Bus encryption flags: 13 Highest AACS version: 70 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.55/ID60 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
TheGame21x
Hmm, I tried running it according to the instructions but received an error message saying "failed to send kernel". Did I do something wrong?
Are you on Windows? Some VMs fail. Use VMWare.TheGame21x wrote: Fri Nov 07, 2025 9:28 pm Hmm, I tried running it according to the instructions but received an error message saying "failed to send kernel". Did I do something wrong?
TheGame21x
Yes, I'm on Windows 10. I can try using VMWare. the firmware I received was for the BDR-211, will that work for my 209M drive? Thanks for the help!Coopervid wrote: Fri Nov 07, 2025 9:42 pmAre you on Windows? Some VMs fail. Use VMWare.TheGame21x wrote: Fri Nov 07, 2025 9:28 pm Hmm, I tried running it according to the instructions but received an error message saying "failed to send kernel". Did I do something wrong?
nicholfd
I don't think he was indicating a VM improves the process - just that if you are using a VM, the settings of the virtualization app/virtual machine may cause issues.TheGame21x wrote: Fri Nov 07, 2025 9:45 pmYes, I'm on Windows 10. I can try using VMWare. the firmware I received was for the BDR-211, will that work for my 209M drive? Thanks for the help!Coopervid wrote: Fri Nov 07, 2025 9:42 pmAre you on Windows? Some VMs fail. Use VMWare.TheGame21x wrote: Fri Nov 07, 2025 9:28 pm Hmm, I tried running it according to the instructions but received an error message saying "failed to send kernel". Did I do something wrong?
I exclusively use macOS as my primary computer OS. I have never had a failure with MakeMKV/flashing tools in Windows 10 & 11 VMs, on UTM (Free/Open Source), vmWare Fusion & Parallels. Due to licensing & what I own, I often switch between Win 10/11 VMs on all three virtualization apps, when working with/flashing optical drives that require Windows.
Thanks,
Frank
