Public KeyDB Disc Submissions
Disc type: UHD
Disc dump filename: MKB20_v82_36_QUAI_DES_ORFEVRES_4108
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link: N/A
Disc dump link: https://we.tl/t-AGelC734DG
Many thanks!
Drive: BD-RE BU40N
Many thanks!
Disc type: UHD
Disc dump filename: MKB20_v82_Murder_In_The_First_11E6
Drive: BD-RE BU40N
Disc dump link: https://we.tl/t-12YswwA7aw
Many thanks!
Drive: BD-RE BU40N
Many thanks!
Disc type: UHD
Disc dump filename: MKB20_v82_Scars_Of_Dracula_0CE6.tgz
Drive: BD-RE BU40N
Disc dump link: https://we.tl/t-xZCxXirTU3
Many thanks!
Drive: BD-RE BU40N
Many thanks!
Disc type: UHD
Disc dump filename: MKB20_v82_The_Horror_Of_Frankenstein_64AE.tgz
Drive: BD-RE BU40N
Disc dump link: https://we.tl/t-07ga5pp1Xe
Many thanks!
Drive: BD-RE BU40N
Many thanks!
Hamilton44
Disc type: UHD
Disc dump filename: MKB20_v82_The_Descent_0D44.tgz
Drive: BD-RE ASUS BW 16D1ht
Drive firmware: 3.01
Disc dump link: https://we.tl/t-4nup18TkTi
keydb_helper
Thanks for the disc dumps MKVDUDE. All seven discs have been added to the public keydb.
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Excellent - Many Thanks!keydb_helper wrote: ↑Sat Nov 08, 2025 12:13 amThanks for the disc dumps MKVDUDE. All seven discs have been added to the public keydb.
Hello, just have some times during weekend. After I flashed the firmware the discs suddenly become readable. Guess someone has already submit them.Coopervid wrote: ↑Mon Nov 03, 2025 5:32 pmThere is a high chance that your drive is not libredrive enabled if you have this firmware. Check your Makemkv info if it says libredrive enabled. If not your links are useless since bus encrypted. Then flash your drive with LG BU40N firmware. Afterwards post new dumps.SFD136 wrote: ↑Mon Nov 03, 2025 3:20 pmDisc type: BD-ROM
Disc dump filename: MKB_v82_FEAR_AND_DREAMS_EASON_CHAN_D1_0C72.tgz
Drive: BUFFALO Optical Drive (Marketing Model Name: BDXL-PTV6U3-BKB / Drive Platform: MT1959)
Drive firmware: BN14
Did you sync the public keydb within the last 15 minutes?: Yes
Disc dump / MKB_RO.inf link: https://www.mediafire.com/file/69ewk61uwv43ofa/
Disc type: BD-ROM
Disc dump filename: MKB_v82_FEAR_AND_DREAMS_EASON_CHAN_D2_4DEE.tgz
Disc dump / MKB_RO.inf link: https://www.mediafire.com/file/1r31p7xk3rpe5ke/
The drive I used is quite rare in this forum, and I am not so sure whether the dump is valid for submission. Thanks in advance.
Anyway happy ripping
SupermanChamber
Disc type: BD-ROM
Disc dump filename:
MKB_v82_Summer_Pockets 上巻 DISC_1_BCD2.tgz
MKB_v82_Summer_Pockets 上巻 DISC_2_61DE.tgz
MKB_v82_Summer_Pockets 上巻 DISC_3_8DC0.tgz
MKB_v82_Summer_Pockets 上巻 DISC_4_8FD6.tgz
Drive: BD-RE BH16NS55
Drive firmware: 1.04
Disc dump link: https://www.mediafire.com/file/om8klxxb ... p.zip/file
Disc dump filename:
Mythbuster
here is my dump file, hope you can help to decrypt.
Disc type: UHD
Disc dump filename: MKB20_v82_Didi_-_Und_die_Rache_der_Enterbten_99CC
Drive: Asus BW-16D1HT
Drive firmware: 3.10MK
Disc dump link: https://drive.google.com/file/d/1dT0vzN ... sp=sharing
Thank You
Disc type: UHD
Thank You
Didi und die Rache der Enterbten
https://www.mediafire.com/file/kbu53kb8 ... C.tgz/file
Edgarhouse
Disc type: UHD
Disc dump filename: MKB20_v68_The_Dark_Knight_291B.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
Disc dump link: https://drive.google.com/file/d/1CGvqus ... sp=sharing
First time posting in the forum so let me know if there's anything I can improve. Thanks
keydb_helper
SupermanChamber wrote: ↑Sat Nov 08, 2025 9:25 amDisc dump filename:
Hamilton44, SupermanChamber, and Mythbuster: Thank you all for following the submission template. Your discs have been added to the public keydb.Mythbuster wrote: ↑Sat Nov 08, 2025 2:55 pmDisc dump filename: MKB20_v82_Didi_-_Und_die_Rache_der_Enterbten_99CC
Hey Edgarhouse, welcome to the forum and thanks for following the template. Your disc variant has been added to the public keydb. In the future, if a UHD disc dump is below 3MB in size you will want to provide the MKB_RO.inf file from your disc. You were lucky this time that the media key was already known to the public keydb but this isn't always the case.
cartload88
Disc type: UHD
Disc dump filename: MKB20_v82_EYES_WIDE_SHUT_8880
Drive: BD-RE BU40N
Disc dump link: https://drive.google.com/file/d/1aENCgL ... sp=sharing
Drive: BD-RE BU40N
