Any plans for mk3d creation?
schneifu
#1 Post by schneifu » Fri Feb 17, 2012 3:48 pm
Just wondering if/when you are planning on adding support for creating .mk3d output from 3d blurays. It looks like the format is starting to trickle down into players. The popcorn hour handles mk3d files and now the new Powerdvd 12 does also which should really start to open up the adoption of the format. The only thing missing is an easy to use tool(makemkv) to create them.
Re: Any plans for mk3d creation?
#2 Post by mike admin » Sat Feb 25, 2012 6:02 am
The next version will be able to extract MVC extension stream and save it in MKV (same way as DTS-HD is stored as DTS+extension). Not many players can play MVC video though.
