SDF update November 2025
mracsys
Re: SDF update November 2025
#46 Post by mracsys » Thu Nov 06, 2025 5:11 pm
Confirmed working on Windows with my BDR-208D, thanks a bunch! Drive info below. On Linux, it does not detect the same discs, but that might be a Fedora problem.
Manufacturer: PIONEER
Product: BD-RW BDR-208D
Revision: 1.50
Serial number: ---
Firmware date: 2015-09-24
Bus encryption flags: 13
Highest AACS version: 75
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.50/ID61
zittrig
#47 Post by zittrig » Thu Nov 06, 2025 6:02 pm
Great work Mike, thanks a lot! :)
Artefakt
#48 Post by Artefakt » Thu Nov 06, 2025 9:09 pm
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: CIDL007887WL
Firmware date: 2023-01-06
Highest AACS version: 81
Drive platform: RS8E21
Firmware version: 1.03/ID05
Unfortunately, I cannot load either a Blu-ray or a UHD disc. :(
jinx100
#49 Post by jinx100 » Fri Nov 07, 2025 2:25 am
Works great! No UHD but not expected for this drive.
Initial:
OS device name: E:
Product: BD-RW BDR-X13
Revision: 1.04
Serial number:
Firmware date: 2023-08-01
Highest AACS version: 76
Drive platform: Pioneer RS9400
Firmware version: ID56
With sdf_0000009c.bin:
Revision: 1.04
Serial number:
Drive platform: RS9400
Firmware name: PIONEER BDR-213T
Firmware version: 1.04/ID56
chnandler_bong
#50 Post by chnandler_bong » Fri Nov 07, 2025 6:39 am
Holy crap on a cracker, my two BDR-XS07U drives work great. Thanks very much for this!
p1xel8ted
#51 Post by p1xel8ted » Fri Nov 07, 2025 7:00 am
Working perfectly!
OS device name: M:
Revision: 1.03
Serial number: DEDL008662WL
Highest AACS version: 82
tommik128
#52 Post by tommik128 » Fri Nov 07, 2025 10:33 pm
VA1DER wrote: Wed Nov 05, 2025 9:21 pm That is a surprise. Pre-2022 drives are used as-is for UHD ripping, or so it's claimed elsewhere. I always thought the only reason newer drives couldn't be used for UHD was the lack of LibreDrive.
Who told you this? Even if it is a pre-2023 Pioneer with LibreDrive enabled, it does not mean it will do UHD discs. It must be an "ultra HD ready" Pioneer model or you need to flash the firmware to UHD model.
#53 Post by Coopervid » Fri Nov 07, 2025 11:03 pm
tommik128 wrote: Fri Nov 07, 2025 10:33 pm
Most of these drives can be crossflashed for UHD.
Mr_Orange
#54 Post by Mr_Orange » Sat Nov 08, 2025 1:55 am
Coopervid wrote: Fri Nov 07, 2025 11:03 pm
How? Why can't the flasher be made available for download now?
#55 Post by MartyMcNuts » Sat Nov 08, 2025 2:38 am
Mr_Orange wrote: Sat Nov 08, 2025 1:55 am
Because the person that wrote it does not want it publicly available.
Mr_Orange
#56 Post by Mr_Orange » Sat Nov 08, 2025 2:44 am
MartyMcNuts wrote: Sat Nov 08, 2025 2:38 am
Why not? I understood that logic when Pioneer were producing drives but now that they aren't and Libredrive is being enabled across many more drives, what is the issue?
#57 Post by MartyMcNuts » Sat Nov 08, 2025 3:16 am
Mr_Orange wrote: Sat Nov 08, 2025 2:44 am
I don't want to speculate. The author asked us not to share it so we (well at least I do) respect this.
VA1DER
#58 Post by VA1DER » Sat Nov 08, 2025 3:49 am
People talking about using the X13_BK drives for UHD is fairly common. I suppose what was meant was that they could be cross flashed, but many discussions don't make that clear and somewhere in all my travels I mistakenly equated the X13_BK with being an S13_BK in an enclosure.
Mr_Orange
#59 Post by Mr_Orange » Sat Nov 08, 2025 4:27 am
MartyMcNuts wrote: Sat Nov 08, 2025 3:16 am
Fair enough. How would one carry out a cross flash then?
#60 Post by MartyMcNuts » Sat Nov 08, 2025 4:31 am
Mr_Orange wrote: Sat Nov 08, 2025 4:27 am
For older Pioneer drives with the pre Dec 2022 firmware, contact Billycar11. For Pioneer drives with the newer firmware, they cannot be cross-flashed at this stage.
