Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
Re: Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
Is the only difference between the different BDR-XD08s color?
yes color only
all are identical inside and have been flashed with UMBS UHD FW
ok everyone i am officially selling drives again for now there are only xd08's
i might get the rare s13ux/ubk or x13ux/us but the xd08 will be most of the stock
Billycar11 wrote: ↑Fri Nov 07, 2025 4:48 amok everyone i am officially selling drives again for now there are only xd08's
Is your email the best way to place an order?
its the only waySodas wrote: ↑Fri Nov 07, 2025 5:09 amBillycar11 wrote: ↑Fri Nov 07, 2025 4:48 amok everyone i am officially selling drives again for now there are only xd08's
I am going back and forth on this. Really wish you had a SATA based drive in stock, as that's really what I am after.
I don't "know" the model billycar11 is selling (slim-line vs. 5 1/4"), but if it is a 5 1/4" sized drive/chassis, there's a 99% chance you could remove the drive from the USB chassis & use it simply as a SATA drive. If it's a slim-line drive, those are SATA also (internal drive). You would need a slim-line -> 5 1/4" drive bay adapter for whatever computer you were going to put it into, and a SATA/power adapter cable (something like this: https://www.amazon.com/SATA-Optical-Dri ... B00D7SRREO)
The 5 1/4" Pioneer drives I have for sale are branded/in an ASUS USB chassis. Two screws removed & snap the case apart. Drive can be removed & used as an internal SATA drive. One buyer has done exactly this with two drives.
Thanks,
Frank
For sale 4K UHD Flashed USB drives:
ASUS Slim, Buffalo Slim, LG Slim,
Buffalo 5 1/4", ASUS 5 1/4",
drives@nicholasfamilycentral.com
Thanks, I suspect you'll be inundated with orders soon, but order placed/payment sent.Billycar11 wrote: ↑Fri Nov 07, 2025 5:13 amits the only waySodas wrote: ↑Fri Nov 07, 2025 5:09 amBillycar11 wrote: ↑Fri Nov 07, 2025 4:48 amok everyone i am officially selling drives again for now there are only xd08's
The model Billy has are the XD08's which are slimline with a flip top to pull the disc out (akin to old Discmans). Not something compatible with anything to put in a case.nicholfd wrote: ↑Fri Nov 07, 2025 7:50 pmI don't "know" the model billycar11 is selling (slim-line vs. 5 1/4"), but if it is a 5 1/4" sized drive/chassis, there's a 99% chance you could remove the drive from the USB chassis & use it simply as a SATA drive. If it's a slim-line drive, those are SATA also (internal drive). You would need a slim-line -> 5 1/4" drive bay adapter for whatever computer you were going to put it into, and a SATA/power adapter cable (something like this: https://www.amazon.com/SATA-Optical-Dri ... B00D7SRREO)
Thanks,
Frank
If you have a 5 1/4" based ones, whether it is in an enclosure or not, then I'm definitely interested in what you have to offer. I didn't know you had any. When I last looked around, it seemed like no one had them in stock.
Oh, also, email sent!nicholfd wrote: ↑Fri Nov 07, 2025 7:50 pmI don't "know" the model billycar11 is selling (slim-line vs. 5 1/4"), but if it is a 5 1/4" sized drive/chassis, there's a 99% chance you could remove the drive from the USB chassis & use it simply as a SATA drive. If it's a slim-line drive, those are SATA also (internal drive). You would need a slim-line -> 5 1/4" drive bay adapter for whatever computer you were going to put it into, and a SATA/power adapter cable (something like this: https://www.amazon.com/SATA-Optical-Dri ... B00D7SRREO)
Thanks,
Frank
Thanks for the info on what Billy has available.Hellmark wrote: ↑Fri Nov 07, 2025 11:38 pmThe model Billy has are the XD08's which are slimline with a flip top to pull the disc out (akin to old Discmans). Not something compatible with anything to put in a case.nicholfd wrote: ↑Fri Nov 07, 2025 7:50 pmI don't "know" the model billycar11 is selling (slim-line vs. 5 1/4"), but if it is a 5 1/4" sized drive/chassis, there's a 99% chance you could remove the drive from the USB chassis & use it simply as a SATA drive. If it's a slim-line drive, those are SATA also (internal drive). You would need a slim-line -> 5 1/4" drive bay adapter for whatever computer you were going to put it into, and a SATA/power adapter cable (something like this: https://www.amazon.com/SATA-Optical-Dri ... B00D7SRREO)
Thanks,
Frank
Mine are 5 1/4". See the links/threads in my signature for 5 1/4" ASUS branded USB drives. I have some with LG drives & some with Pioneer drives in them. I have both on hand - I update the first post in my thread periodically with stock & avaialability info.
Thanks,
Frank
I just got my XD08 drive from Billycar11.
Worked great out-of-the box, zero complaints.
Unrelated to the service Billycar11 provides, but be aware that the cable the drive comes with is very short (like less than a foot). Fortunately it's USB-C so not hard to find a longer cable if you want one.
Drive arrived safely, tested it briefly and everything seems to work correctly. Thanks Billy!
Hi, I did put in a purchase for a Pioneer XD08B two days ago.
