Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
walk2k
Post by walk2k »
MartyMcNuts wrote: Fri Oct 31, 2025 10:52 pm
walk2k wrote: Fri Oct 31, 2025 10:27 pm Hi all. new to all this, just wanted to report success. I recently purchased an external LG drive (LG BP50NB40 purchased from Best Buy on 10/27/25 for about $91). it has a manuf'd date of May 2025 and came with (if I remember) firmware version 1.04.
I followed the directions here, first flashed it to version "BP50NB40-NB50-1.03MK" then to > "BP60NB10 1.02MK"
the drive in makemkv says it's on version "1.03" but it does report LibreDrive "Patched (microcode access re-enabled)" and "Yes" for all the options.
I haven't tried any UHD discs yet (because I don't have any) but it does work fine with 1080p Blu-ray, as well as DVD and CD. Oh, and if anyone knows how to rip SA-CD (yes those) let me know.. I tried a few different programs but none work..
I've recently installed a NAS, the UGreen 4300, and it's great. The HDMI out unfortunately doesn't support some BD formats (VC-1) so those won't play, but using Jellyfin works great. I actually love Jellyfin right now, and I've never used a NAS or done anything like that before..
On a side note, since I intend to rip all of my old DVDs (about 200) and my music CDs (almost 1000) again, this time in FLAC.. I figured I would dig out an old DVD drive (internal SATA) from storage and hook it up for burning those. I only have about 20 BDs so the LG drive will be ok for those, but ~1200 discs is a lot of usage on what seems like a pretty flimsy thing..
WELL you know how they tell you if you have a modular power supply in your PC, ONLY use the power cables that came with the unit, and not any other brand, or unknown cables? I mean, it's a Molex/SATA cable, how different can they be? OOPS. I apparently let the magic smoke out, totally fried the SATA interface board on this old Asus drive (crispy noises and flashes of light).. so I guess I won't be using that... :shock:
If ist still shows in MakeMKV as BP50NB40 1.03 firmware, then you haven't done the cross-flash correctly. It should say BP60NB10 1.02. As is, it will not work with UHD discs as the BP50NB40 firmware is not UHD compatible. Libredrive does not mean UHD compatible.
Ok I think I got it. I did it wrong(tm). To be fair, I simply missed the fact mine is a "NB52" drive. Which doesn't show up anywhere but printed on the label on the bottom of the drive.. and the instructions aren't super clear. I used the guide in the SDFtool thread:
"For the moment, to flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follw the steps below:
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
Now for the crossflash:
2. Select the RECOVERY option and in the pop up, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select the BP60NB10 1.00-MK or BU40N 1.00 firmware in the normal drop box.
4. Click START"
seems like that worked:
OS device name: E:
Product: BD-RE BP60NB10
Revision: 1.00
Serial number: SIM2121M60954
Firmware date: 2117-11-21 17:20
Highest AACS version: 23
Firmware version: 1.00
Th3Color wrote: Sat Nov 01, 2025 2:36 pm Hello all,
I have a problem in that my drive simply won't work with 4K discs. It reads all other types, but not 4K discs.
It also disconnects from the PC briefly every time it tries to read the disc. Could this be another problem? However, this only happens with 4K discs.
Here is the mkv information:
OS device name: E:
Product: BD-RE BU40N
Revision: 1.03
Serial number: MO9P6390032
Highest AACS version: 18
Firmware version: 1.03
Probably not getting enough power. Use ports direct from the motherboard (USB-C if possible, otherwise USB-A 3+) or an AC self-powered hub of at least 30w. Do not use case ports.
Th3Color
Post by Th3Color »
MartyMcNuts wrote: Sun Nov 02, 2025 4:42 am
OS device name: E:
Revision: 1.03
Thanks for the confirmation. It was a usb extansion that coused the error. Everything is working now.
guide updated info about UHD pioneers now working with latest FW
sero12
Post by sero12 »
Hello at all,
I have a problem in that my drive simply won't work with 4K discs. It reads all other types of disks, but not 4K discs.
OS device name: F:
Product: BD-RE BH16NS55
Revision: 1.02
Serial number:
Firmware date: 2115-12-11 14:40
Firmware version: 1.02
zittrig
Post by zittrig »
Have a good look into the very first post in this thread.
Use the SDF Flashing Tool for flashing directly to firmware LG WH16NS60 1.02MK.
You can find the download link for the tool and the firmware pack also there ----> viewtopic.php?f=16&t=22896
Try it. :wink:
nonchu
Post by nonchu »
Forgive me if this isn't the correct place to say this or if its not usful but I've found that this adapter worked with makemkv and doesn't show the drive as generic, at least with my BU40N and a slimline adapter.
https://www.amazon.com.au/dp/B07SCY623F ... asin_title
Carlangas
Post by Carlangas »
goestoeleven wrote: Fri Oct 31, 2025 10:34 pm Hi gang. Newb here and very late to the party. There are hundreds of pages here, so I hope you'll forgive the question and help a brother out:
Just picked up an LG drive from OWC. It's not currently reading UHD disks, even though the techs there said it could.
Here's what MakeMKV is reporting:
Product: BD-RE BH16NS40
Revision: 1.05
Serial number: <redacted>
Firmware date: 2120-05-06 13:31
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.05
Out of the box it can read BD Audio disks, but it can't see UHD disks. It also seems to not be able to read the MLP tracks on DVD-Audio disks (just the DD content). Is there a firmware I can use to make both UHD and DVD-A ripping possible?
I'm reasonably technical and can follow a procedure if I've got the right tools.
Thanks in advance for your help!
Hi! were you able to get it flashed? I have the same drive
zittrig
Post by zittrig »
Yes, it can be flashed.
Just have a look to my post from yesterday, 6.58 PM.
But post your drive information also before doing some flashing. Drive platform is MT1959 also?
TheBesto
Post by TheBesto »
Hey guys!
I'm starting to look into saving my physical blu-ray collection into a digital one in order to avoid potentially losing them in the future.
As one can notice, I ended here (coming from the LTT video from a bit more than a year ago).
As a software engineer, I'm trying to understand what's behind the scene regarding all the steps that are linked in the tutorial on first page.
I do understand the need for a drive that can read Blu-Rays (duh), but then I fall a bit short on what the flashing step is supposed to be for.
Can someone explains a bit what it does? Is it to enable 4K HDR support on drives that does not have it? Is it to enable reading protected blu-rays as if they were not? Both, something else?
Also, it seems that, at least in France, most of the drives referenced in the tutorial are not available anymore to purchase.
The only exception is the Buffalo BRUHD-PU3-BK which I do find on Amazon, but it is quite expensive.
Do you have any recommandation there? It seems that the Asmcom website that would deliver pre-flashed drives is not available at the time (getting connection errors when trying to go there).
Thanks in advance :)
TheBesto wrote: Sun Nov 09, 2025 5:55 pm Hey guys!
Buy a Verbatim 43888, 43889 or 43890. They contain a LG BU40N that can be flashed.
https://www.amazon.fr/-/en/VERBATIM-Sli ... 103&sr=8-6
xwmkf
Post by xwmkf »
TheBesto wrote: Sun Nov 09, 2025 5:55 pm As a software engineer, I'm trying to understand what's behind the scene regarding all the steps that are linked in the tutorial on first page.
I believe both; my understanding is that:
  • having a firmware that's recognized by libredrive makes handling the AACS decryption better
  • "cross-flashing" a drive to another firmware can allow it to read UHD/4k discs where it couldn't read them before
  • in general flashing a drive can accomplish both of the above
TheBesto wrote: Sun Nov 09, 2025 5:55 pm Also, it seems that, at least in France, most of the drives referenced in the tutorial are not available anymore to purchase.
It's not a lot different in the US (and possibly globally); lots of drives are hard to find. I can't recommend anything for France. In the US the BP50NB40 is the only one I've found reliably from retail (and then, only Best Buy).
TheBesto
Post by TheBesto »
Thanks for the replies and suggestions.
I've ordered a Verbatim 43888, I'll keep you posted when I receive it and made my first ripping tests!
goestoeleven
Post by goestoeleven »
Carlangas wrote: Fri Nov 07, 2025 4:07 am
Revision: 1.05
Yes, with help from Billy I am in business! Money well spent!
sevoflurane
Post by sevoflurane »
ANother newbie here, though I am a long standing MakeMKV user and have been an avid ripper of CDs, DVDs of all types and SACDs for years. I have only one UHD BD, and am wondering if the following drive would be capable of ripping it so I can play the rip on my 4K TV.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 8.11
Serial number: redacted.
Firmware date: 2014-01-16
Highest AACS version: 82
Drive platform: RS8600
Firmware version: 8.11/ID52
No disc inserted.
Note that the drive is in a Buffalo enclosure and was marketed at a BRXL 16U3. I have seen comments here stating that some Buffalo enclosures prevent flashing, and could remove the drive and rehouse it in the Icy Box enclosure that currently houses an older LG BD drive used for CD ripping.
I think the last time I flashed the firmware of an optical drive was over 20 years ago to make it region free, so I am somewhat out of practice. I will keep on reading the vast amount of information on this forum to educate myself further, but if anyone knows and has a quick answer it would be much appreciated!
