LG BU40N Died in Verbatim 43888, replace with Pioneer BDR-UD04 in same enclosure?
The prodigy
Post by The prodigy »
Hi, my verbatim with LG drive just died, making clicking noise now and spitting out discs.
Does anyone know if I can keep the enclose and swap out the drive with a Pioneer BDR-UD04?
I know the same model verbatim came with the pioneer, but wondering if there are other internals that would be different, or if it’s simply a different drive.
Any advice or input is greatly appreciated as I am now in the market for a Pioneer, with what looks like very little options at this point.
Re: LG BU40N Died in Verbatim 43888, replace with Pioneer BDR-UD04 in same enclosure?
You can't find an UD04 or UD03 unless you are lucky on ebay. Don't buy from China. Mostly scams.
The prodigy
Coopervid wrote:
Wed Nov 05, 2025 9:12 pm
Thank you for your reply. I can’t seem to find any pioneer drive that would ship from the US at the moment. What would recommend? Thanks
I can't. Production stopped. So you have to check online and be lucky.
The prodigy wrote:
Wed Nov 05, 2025 10:02 pm
I think Billycar11 has some for sale. Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
