Public KeyDB Disc Submissions
DavidF
Post by DavidF »
Apologies. I did drag the related TGZ file to each post. They showed up in the attachment section, so I assumed that was successful. I didn't catch that there was a small yield indicator under status. But after clicking that, I now see that it says "the board attachment quota has been reached".
I have copied the files to Google drive and will re-post and attach the links. Here's the first one. Thanks!
Title: A Star Is Born (2018) UHD 4K
Dump filename: MKB20_v66_A_STAR_IS_BORN_2018_0331.tgz
Region: [USA]
MakeMKV: v1.18.2 (Windows), LibreDrive Enabled
Physical disc: Yes (on hand)
https://drive.google.com/file/d/1Z_Nw-a ... sp=sharing
DavidF
Post by DavidF »
Title: Aquaman (UHD 4K)
Dump filename: MKB20_v68_AQUAMAN_5D07.tgz
Region: [USA]
https://drive.google.com/file/d/1WmIOxl ... sp=sharing
DavidF
Post by DavidF »
Title: Batman v Superman: Dawn of Justice – Ultimate Edition (UHD 4K)
Dump filename: MKB20_v61_BATMAN_V_SUPERMAN_UE_945F.tgz
Region: [USA]
https://drive.google.com/file/d/1ozJPkQ ... sp=sharing
DavidF
Post by DavidF »
Title: Wonder Woman (UHD 4K)
Dump filename: MKB20_v61_WONDER_WOMAN_7A97.tgz
Region: [USA]
https://drive.google.com/file/d/19zooUM ... sp=sharing
DavidF
Post by DavidF »
Title: The Greatest Showman (UHD 4K)
Dump filename: MKB20_v61_THE_GREATEST_SHOWMAN_2D95.tgz
Region: [USA]
https://drive.google.com/file/d/1JuKMep ... sp=sharing
DavidF
Post by DavidF »
Title: Bohemian Rhapsody (UHD 4K)
Dump filename: MKB20_v66_BOHEMIAN_RHAPSODY_65F1.tgz
Region: [USA]
https://drive.google.com/file/d/1O8Io2Q ... sp=sharing
keydb_helper
Post by keydb_helper »
bdsucker wrote: Tue Nov 04, 2025 9:25 am MKB20_v82_SPOTLIGHT_B396
Mythbuster wrote: Tue Nov 04, 2025 7:11 pm MKB20_v82_Dr_Seuss’_How_the_Grinch_Stole_Christmas_0648
efgaleuh wrote: Tue Nov 04, 2025 7:42 pm MKB20_v61_VENOM_2018_4AF3
bdsucker, Mythbuster, and efgaleuh: Your discs have all been submitted to the public keydb. In the future please use the submission template in the opening post. Otherwise, your disc dumps will eventually be processed but they will be de-prioritized in favour of the submissions which follow the submission template.
DavidF wrote: Wed Nov 05, 2025 2:54 am Apologies. I did drag the related TGZ file to each post. They showed up in the attachment section, so I assumed that was successful. I didn't catch that there was a small yield indicator under status. But after clicking that, I now see that it says "the board attachment quota has been reached".
Hi David, all of your disc dump files are below the 3MB file size threshold, so you should've included the MKB_RO.inf file from your discs. Fortunately for you, most of your discs are variants of existing discs with known media keys so complete records could still be created and submitted to the public keydb. The only exception to this was A Star Is Born which will require you to provide the MKB_RO.inf before it can be supported.
In the future, please read the opening post carefully and follow the template I provided rather than using your own template. The Region is irrelevant for our purposes, but the MKB_RO.inf file is important.
Rey111
Post by Rey111 »
Rey111 wrote: Tue Nov 04, 2025 6:22 pm I sent an email with the dump file svq@makemkv.com
MKB20_v77_CROW_REMASTERED_3293
I am not sure if that is the latest correct procedure.
Thanks for your great help.
Hey Rey111, sorry but that is not the correct procedure for this thread. Did you notice how your post is quite distinct from every other post as they actually provide links to disc dump files? If you'd like to contribute please read the first post in this thread.
[/quote]
Ok i understand. i read the first post, and I have a Pioneer drive, is there anything else i can do? (Create a new post with correct template and attach the requested files from Pioneer) or what should i do in this case.
Thanks for the info.
WeapX
Post by WeapX »
Disc type: BD
Disc dump filename: MKB_v82_Cecil_B_Demented_3060
Drive: BW-16D1HT
Drive firmware: 3.10
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://drive.google.com/file/d/1TsA5DB ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1BcB5RX ... sp=sharing
mkvliker
Post by mkvliker »
Disc type: BD
Disc dump filename: MKB_v82_EYXA_14709_0790
Drive: ASUS SBW-06D2X-U
Drive firmware: 1.10
LibreDrive status: Possible, not yet enabled
MKB_RO.inf link: https://mega.nz/file/DbQA1I6R#7OCj-8Jhs ... vjE_F7DGUI
Disc dump link: https://mega.nz/file/iCIRXa7Q#x7rv_Yp97 ... nWMkTh_-mM
Disc type: BD
Disc dump filename: MKB_v82_EYXA_14738_75E4
MKB_RO.inf link: https://mega.nz/file/qKoDhSzK#NWTeFQg7l ... RZrKp0-EMU
Disc dump link: https://mega.nz/file/vWwlzB7B#WZiI6HS-X ... vg0C7Hl09U
Hittsy
Post by Hittsy »
Disc type: 1080p blu-ray
Disc dump filename: MKB_v82_ARCANE_SEASON_2_-_DISC_2_EAE4
Drive: ASUS BW-16D1H-U
Drive firmware: 0.A204W
MKB_RO.inf link: https://drive.google.com/file/d/1weqpcI ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1J5hSEf ... sp=sharing
The first disk I've had AACS v82, which seems to prevent my flashed player from opening even this 1080p blu-ray disk without a key. Disks 1 and 3 were successful, with the DB, but disk 2 (this one) wasn't in the DB for some reason (maybe 1 & 3 had the same key as some other entry through dumb luck?)
keydb_helper
Rey111 wrote: Wed Nov 05, 2025 5:58 pm Ok i understand. i read the first post, and I have a Pioneer drive, is there anything else i can do? (Create a new post with correct template and attach the requested files from Pioneer) or what should i do in this case.
Hey Rey111, feel free to follow the submission template and post your disc dump. It is entirely possible that nothing will be possible due to the limitations with Pioneer disc dump files but it is worth a shot.
If possible, I'd definitely recommend buying an LG/Asus drive as a fallback option for useful disc dump file generation.
WeapX wrote: Wed Nov 05, 2025 7:21 pm Disc dump filename: MKB_v82_Cecil_B_Demented_3060
mkvliker wrote: Wed Nov 05, 2025 7:58 pm Disc dump filename: MKB_v82_EYXA_14709_0790
Hittsy wrote: Wed Nov 05, 2025 11:37 pm Disc dump filename: MKB_v82_ARCANE_SEASON_2_-_DISC_2_EAE4
WeapX, mkvliker, and Hittsy: Thanks for following the submission template. Your discs have been added to the public keydb.
mkvliker wrote: Wed Nov 05, 2025 7:58 pm Drive: ASUS SBW-06D2X-U
I'd recommend looking at the LibreDrive options for your drive mkvliker. It can still be very useful for 1080p Blu-ray discs.
mattmak464
Post by mattmak464 »
Jacob's Ladder UHD
MKB20_v82_BDROM_B082.tgz
https://drive.google.com/file/d/1Z3ZACv ... share_link
99gagamel
Post by 99gagamel »
Disc-Typ: UHD
Disc-Dump-Dateiname: MKB20_v66_HALLOWEEN_18_0ED5,tgz
Laufwerk: BH16NS55
Laufwerks-Firmware: 1.05
Haben Sie die öffentliche Schlüsseldatenbank in den letzten 15 Minuten synchronisiert? Ja
Haben Sie überprüft, ob alle Einreichungslinks im Inkognito-/Privatmodus erreichbar sind? Ja
Link zur Datei MKB_RO.inf: https://drive.google.com/file/d/1Lk0fTI ... sp=sharing
Link zum Disc-Dump: https://drive.google.com/file/d/1vjfbrz ... sp=sharing
Lightyear
Post by Lightyear »
Disc type: UHD
Disc dump filename: MKB20_v82_Crocodile_Dundee_-_The_Encore_Cut_CCBE
Drive: WH16NS60
Drive firmware: 1.02
Disc dump link: https://drive.google.com/file/d/1KjnFJC ... drive_link
