Funny little messsage: doesn't affect anything
baraktorvan
Post by baraktorvan » Wed Nov 05, 2025 3:51 pm
Doing the Makemkv thing, and in every disk I am now seeing (since 1.82) in the log file.
Downloading latest SDF to C:\Users\Troy/.MakeMKV ...
Automatic SDF downloading is disabled or failed.
I don't see that option in Preferences, so I haven't knowingly disabled anything.
Internet access is not a problem, just checked that. Firewall is working normally. Logged into router-all is normal there.
Any idea? It doesn't affect the projects at all, just sits there in the log doing nothing.
Thanks,
Troy
Windows 11 25H2
Re: Funny little messsage: doesn't affect anything
Post by Woodstock » Wed Nov 05, 2025 4:08 pm
Yes, it IS saying that something is affected - the ability to download the SDF file. Usually that means your ISP or router is blocking access to the Russian site that hosts the SDF file, but that can be worked around USUALLY.
Post by dcoke22 » Wed Nov 05, 2025 4:30 pm
Woodstock is right… usually an ISP or a firewall is blocking access. At the moment, however, there is a bug that might be the root cause.
https://forum.makemkv.com/forum/viewtopic.php?f=19&t=39871&p=186869#p186869
