Tried to make a copy of DVD to hard drive, I get this error when I start the scan of the DVD:
Debug log started at Wed Nov 11 21:56:36 2009 , written by MakeMKV v1.4.8 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.8 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Users\Main/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 0 at dSxz^+8VEkv' -.':213133158
003010:000000:0000 Using direct disc access mode
003002:003011:0010 Calculated BUP offset does not match one in IFO header.
003014:000000:0000 Title #0 with special attributes was skipped
005010:000000:0000 Failed to open disc
ERROR-Calculated BUP offset does not match one in IFO header
- Contact:
Re: ERROR-Calculated BUP offset does not match one in IFO header
this is known error and will be corrected in a next version.
