SDF update 2025
Konten
Re: SDF update 2025
Post by Konten »
Coopervid wrote: Tue Nov 04, 2025 10:03 pm Manual download. Somebody to post if automatic is working. I doubt it.
This is true, for me at least automatic download wasn't working either.
Re: SDF update 2025
jayper wrote: Tue Nov 04, 2025 10:10 pm How do we manually download?
https://www.makemkv.com/svq/sdf.bin
Re: SDF update 2025
Post by mike admin »
Coopervid wrote: Tue Nov 04, 2025 9:57 pm Mike, the automatic download doesn't work.
Sigh. Confirmed. Not related to network. Working on a fix.
Re: SDF update 2025
Fixed, download should work now.
Re: SDF update 2025
mike admin wrote: Wed Nov 05, 2025 10:22 pm Fixed, download should work now.
Super. Will try on the other PC.
AvidWalker
Re: SDF update 2025
Post by AvidWalker »
It works!
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: xxxxxxxxxxxxxxx
Firmware date: 2022-12-27
Highest AACS version: 76
Drive platform: RS9331
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02/ID05
halstedmichael
Re: SDF update 2025
Post by halstedmichael »
I may be smooth braining it over here, but the program for me isn't finalizing the download for me. It continues to download "Downloading latest SDF to C:\Users\halst.DESKTOP-OA8A8RA/.MakeMKV ..." as the message. And my drive isn't reading discs.
OS device name: E:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: SIK9NH989213
Highest AACS version: 82
Re: SDF update 2025
halstedmichael wrote: Thu Nov 06, 2025 1:58 am I may be smooth braining it over here, but the program for me isn't finalizing the download for me. It continues to download "Downloading latest SDF to C:\Users\halst.DESKTOP-OA8A8RA/.MakeMKV ..." as the message. And my drive isn't reading discs.
OS device name: E:
Revision: 1.02
Then manually download sdf.bin (the link is a few posts back) and add it to your MAkeMKV data directory. When you open MakeMKV next, it will be absorbed in to _private_data.tar
Konten
Re: SDF update 2025
Post by Konten »
Just a heads-up: Automatic downloading of v09c not working here at the moment:
Downloading latest SDF to /Users/admin/Library/MakeMKV ...
DEBUG: Code 0 at xz[*FizY@*&eS]a:121263107
Automatic SDF downloading is disabled or failed.
DEBUG: Code 156 at iwR'HM::<wMf\TLm:213144796
Manual download works fine.
Unplanned9977
Re: SDF update 2025
Post by Unplanned9977 »
OS device name: E:
Revision: 1.02
The LibreDrive status does show enabled so it should work. Maybe the ole disconnect/reconnect drive close/reopen MakeMKV will clear it up.
