All Pioneer drives will be LibreDrive supported
M7153DRC
Re: All Pioneer drives will be LibreDrive supported
Post by M7153DRC » Sun Oct 19, 2025 1:35 am
Could you PM me pricing on your drives? Thanks!
VA1DER
Post by VA1DER » Mon Oct 20, 2025 5:45 pm
g0th1ckn1ght wrote:
Fri Oct 17, 2025 8:26 pm
Coopervid wrote:
Fri Oct 17, 2025 8:19 pm
You gotta wait until Mike comes up with a solution. No ETA. But he pomised.
No worries. I have an LG that I bought from Marty that I am using in the meantime. Cheers
Word on the street from sources I would consider reliable is that it will be Real Soon Now(tm),
Mr_Orange
Post by Mr_Orange » Tue Nov 04, 2025 10:05 pm
mike admin wrote:
Mon Nov 03, 2025 10:56 pm
viewtopic.php?f=19&t=39858
"You are not authorised to read this forum" - what gives?
Post by Coopervid » Tue Nov 04, 2025 10:06 pm
That was a temporary message.
Unplanned9977
Post by Unplanned9977 » Tue Nov 04, 2025 10:08 pm
Mike basically reset that post:
viewtopic.php?f=19&t=39869
Post by Coopervid » Tue Nov 04, 2025 10:09 pm
So? Automatic doesn't work.
Mr_Orange
Post by Mr_Orange » Tue Nov 04, 2025 10:12 pm
Thanks but it didn't redirect.
Unplanned9977
Post by Unplanned9977 » Tue Nov 04, 2025 10:12 pm
Not for me presently but I'm only 1 interested user.
Unplanned9977
Post by Unplanned9977 » Tue Nov 04, 2025 10:15 pm
It wasn't meant to. My guess is he recreated the 'SDF update November 2025' post, which is now the link I shared. Maybe I'm wrong.
OB11BO
Post by OB11BO » Wed Nov 05, 2025 12:17 am
This new SDF, once working, still doesn't make a drive read UHD, right?
Post by MartyMcNuts » Wed Nov 05, 2025 1:06 am
Not unless you have a UHD model.
mossman1120
Post by mossman1120 » Sun Nov 30, 2025 8:49 am
I just want to make sure I am understanding correctly.
Based on the SDF update November 2025 I see that there are a bunch of BDR-209D firmware versions listed:
PIONEER-BD-RW___BDR-209D-1.10-44290838-8600ID61-20130910
PIONEER-BD-RW___BDR-209D-1.20-90EB76E2-8600ID61-20140408
PIONEER-BD-RW___BDR-209D-1.30-6901C899-8600ID61-20141205
PIONEER-BD-RW___BDR-209D-1.31-8CF13BF3-8600ID61-20150525
PIONEER-BD-RW___BDR-209D-1.32-F3AD8FFF-8600ID61-20150825
PIONEER-BD-RW___BDR-209D-1.33-CC733748-8600ID61-20151209
PIONEER-BD-RW___BDR-209D-1.34-FCF25369-8600ID61-20160425
PIONEER-BD-RW___BDR-209D-1.50-7F6800F0-8600ID61-20171221
PIONEER-BD-RW___BDR-209D-1.50-F67F9D64-8601ID61-20171221
PIONEER-BD-RW___BDR-209D-1.51-148709AB-8600ID61-20180508
PIONEER-BD-RW___BDR-209D-1.51-664813FF-8601ID61-20180508
Would this mean that a a BDR-209DBK (I am going to assume that BK means black) manufactured in 2022 it should now work?
Post by MartyMcNuts » Sun Nov 30, 2025 8:58 am
For standard blu-ray, yes. For UHD no. If the firmware is pre 12/2022 it can be cross-flashed to a UHD model firmware.
mossman1120
Post by mossman1120 » Sun Nov 30, 2025 9:08 am
I would be looking to UHD. Is the cross flashing something that I could do myself? I have previous flashed LG drives.
If the drive is manufactured before 12/2022 would that mean the firmware is okay? Would the version be on the label or it is something that would need to be dumped from the drive?
