SDF update 2025
SDF update 2025
#1 Post by Coopervid » Tue Nov 04, 2025 7:59 pm
Automatic SDF downloading is disabled or failed.
This error occurs.
Re: SDF update 2025
#2 Post by mike admin » Tue Nov 04, 2025 8:04 pm
Apparently this is the hosting provider timeout error due to all MakeMKV instances trying to download the file simultaneously. Once it is confirmed that new SDF.bin actually works, direct download link along with manual download instructions will be posted.
Re: SDF update 2025
#3 Post by Coopervid » Tue Nov 04, 2025 8:25 pm
I'll try again tomorrow and will report back.
Re: SDF update 2025
#4 Post by Coopervid » Tue Nov 04, 2025 8:44 pm
Mike, no. Manual download works instantly. So no overload at the hosting provider.
Re: SDF update 2025
#5 Post by Coopervid » Tue Nov 04, 2025 9:20 pm
After the manual download. This laptop has no drive connected:
Debug log started at Tue Nov 04 21:16:24 2025 , written by MakeMKV v1.18.2 win(x64-release)
001005:0000 MakeMKV v1.18.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\xxxxx/MakeMKV_log.txt
No SDF v09b: ELBY_CLONEDRIVE_1.4
DEBUG: Code 3 at R/Ru3B(Mxaw 4&z'5FC}$>4::29395310
SDF id v09b: ELBY_CLONEDRIVE_1.4
Application exited at Tue Nov 04 21:18:00 2025
BeanJump
Re: SDF update 2025
#6 Post by BeanJump » Tue Nov 04, 2025 9:33 pm
Downloaded manually.
BDR-XD08 Looks good:
OS device name: \Device\CdRom2
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.02
Serial number: <omitted>
Firmware date: 2022-12-27
Highest AACS version: 82
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02
Rips a 1080p BD at 2.8x (pretty sure I was only seeing 2x before)
Doesn't load a 4K BD.
BDR-XS07 is unchanged
OS device name: L:
Product: BD-RW BDR-XS07
Revision: 1.03
Firmware date: 2023-01-06
Bus encryption flags: 13
Drive platform: Pioneer RS8E20
Firmware version: GENE
Re: SDF update 2025
#7 Post by mike admin » Tue Nov 04, 2025 9:38 pm
Did it create a (large) fw dump?
Re: SDF update 2025
#8 Post by mike admin » Tue Nov 04, 2025 9:40 pm
MakeMKV downloads the SDF.bin (along with the keys) from different website and from different URL, as no keys are stored on makemkv.com
Re: SDF update 2025
#9 Post by Coopervid » Tue Nov 04, 2025 9:49 pm
Still missing a post with automatic download and success. Just tried with my desktop. Still failed.
Re: SDF update 2025
#10 Post by SamuriHL » Tue Nov 04, 2025 9:51 pm
This is as far as I get:
Downloading latest SDF to C:\Users\samur/.MakeMKV ...
DEBUG: Code 4279353343 at C<7^R'UGghNJsUb:121262877
DEBUG: Code 155 at 3}LEXDFfdV,&S#:f:213144796
BeanJump
Re: SDF update 2025
#11 Post by BeanJump » Tue Nov 04, 2025 9:53 pm
Yes, found and sent. Also sent the SBW-06D5H-U, which is in the same state.
Re: SDF update 2025
#12 Post by Coopervid » Tue Nov 04, 2025 9:57 pm
Mike, the automatic download doesn't work.
Konten
Re: SDF update 2025
#13 Post by Konten » Tue Nov 04, 2025 9:59 pm
Manually downloaded and installed SDF...
Showing as V09b...
And it's working!!! 4K and everything!!!
Thanks so much, Mike, this is really awesome!!! :D
OS device name: /dev/rdisk4
Product: BD-RW BDR-XS08U
Revision: 1.00
Firmware date: 2022-10-11
Highest AACS version: 81
Drive platform: RS9621
Firmware version: 1.00/ID69
Disc Information
Label: <omitted>
Timestamp: 2024-11-14 22:47:58
Protection: AACS2.0/C v77
Data capacity: 77.73 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Re: SDF update 2025
#14 Post by Coopervid » Tue Nov 04, 2025 10:03 pm
Manual download. Somebody to post if automatic is working. I doubt it.
jayper
Re: SDF update 2025
#15 Post by jayper » Tue Nov 04, 2025 10:10 pm
How do we manually download?
