Robin Hood: Prince Of Thieves 1991-Arrow remastered blu-ray
duranduran
Post by duranduran »
Correct playlist for Robin Hood: Prince Of Thieves 1991 - Arrow remastered blu-ray
Can anyone help in regards to the correct playlist for both the theatrical and extended version of the movie?
thank you
JacobHeldt
Re: Robin Hood: Prince Of Thieves 1991-Arrow remastered blu-ray
Post by JacobHeldt »
I Got the same issue. i even Got Libra Drive. can someone help?
DVDCompare.net (https://www.dvdcompare.net/comparisons/film.php?fid=62987) suggests the theatrical version is 143:12 and the extended version 155:02.
JacobHeldt
@dcoke22 - yes there are two cuts of the movie. problem is that there is a lot of playlists for each version when you rip the disc - even with libredrive and java installed.
JacobHeldt
duranduran wrote: Sun Nov 26, 2023 9:36 am Correct playlist for Robin Hood: Prince Of Thieves 1991 - Arrow remastered blu-ray
thank you
Did you ever find out?
JacobHeldt
dcoke22 wrote: Fri Aug 22, 2025 11:22 pm DVDCompare.net (https://www.dvdcompare.net/comparisons/film.php?fid=62987) suggests the theatrical version is 143:12 and the extended version 155:02.
JacobHeldt
JacobHeldt wrote: Sat Aug 23, 2025 1:30 pm
thank you
did you find the right one? thanks
JacobHeldt
as i wrote its a playlist issue - cause the disc has a large amount of playlist for each version - i have libredrive and Java installed - would you have any idea what to do?
thansk J
I don't have that disc, so I don't know what the proper playlists are. This thread has various methodologies you can try. A Better Way To Find The Correct Playlist/Segment Map
JacobHeldt
dcoke22 wrote: Fri Aug 29, 2025 2:27 pm I don't have that disc, so I don't know what the proper playlists are. This thread has various methodologies you can try. A Better Way To Find The Correct Playlist/Segment Map
thanks a lot.
gavins
Post by gavins »
I've just got this and run through the Extended playlist that I think is 01633.mpls
This consists of 21 segments: 04864, 08973, 06017, 0810, 06350, 05482, 08325, 07773, 04185, 06711, 06556, 08431, 07440, 07938, 06959, 08809, 05602, 04589, 07166, 06640, 05274
Note I haven't played this stream through yet!
yeahIdidit
Post by yeahIdidit »
Where can I find this version (usenet?) I could tell you the correct playlist if I can download the iso or BDMV
lilepah
Post by lilepah »
Theatrical segments when played through VLC: 04864, 05738, 06017, 04826, 06350, 05996, 08325, 04185, 04342, 06556, 07440, 04629, 06959, 05602, 07844, 07133, 06820, 05274
It's the 70th playlist entry.
yeahIdidit
Hi, so I got an Arrow source GBR Blu-ray. It has 116 playlist files.
After running my own script on it, the output was 00800.mpls is the correct, extended cut, and 00077.mpls is the theatrical cut.
The source was Robin.Hood.Prince.of.Thieves.1991.2in1.1080p.GBR.Blu-ray.AVC.DTS-HD.MA.5.1-HGN
Hope that helps
Okay, sorry, I was annoyed by the original output, so I ran a stricter heuristic and here are the results for the Blu-ray mentioned above.
Terminal + CSV. Here’s the quick take:
• Scan saw 116 playlists in that BDMV.
• The main cluster of real feature-length titles is at ~9,302s (≈155 min), 22 segments, with identical segment-set signature 59b2f673.
• Members include: 00037.mpls, 00039.mpls, 00290.mpls, 00309.mpls, 00350.mpls, …, 00800.mpls (39 total).
• There’s a single longer cut at ~9,458s (≈158 min), 23 segments, signature 4216e16d → 01620.mpls.
• The bogus/menu monster is 01997.mpls (13,205s, 202 segs, short_lt90_share=1.0) — definitely discard.
What this means (actionable)
• For twin-cut discs like this, pick:
• Theatrical (or the 155-min cut): any MPLS from the 59b2f673 cluster (I’d use 00800.mpls or 00037.mpls).
• Extended (the 158-minute cut): 01620.mpls (signature 4216e16d).
Hope that is clearer, thanks
Detected feature pick(s) with aliases + fingerprints:
Label Rep MPLS Runtime Aliases (same cluster)
theatrical 00075.mpls 02:23:05 00075.mpls 00077.mpls 00081.mpls 00135.mpls 00194.mpls 00201.mpls 00210.mpls 00384.mpls 00412.mpls 00435.mpls 00455.mpls 00466.mpls 00472.mpls 00525.mpls 00754.mpls 00780.mpls 00790.mpls 00794.mpls 00814.mpls 00869.mpls 00891.mpls 00950.mpls 00994.mpls 01051.mpls 01054.mpls 01159.mpls 01214.mpls 01301.mpls 01334.mpls 01337.mpls 01474.mpls 01485.mpls 01524.mpls 01573.mpls 01606.mpls 01735.mpls 01869.mpls
segs=20 first=04864 last=00065 hash=e7b88a754bc118863477100e042b0ce6
extended 01620.mpls 02:37:37 01620.mpls
segs=23 first=04864 last=00065 hash=86f5041aea1ff01aca5708f62f3f4409
Open which cut? [t=theatrical / e=extended / Enter=skip] e
Choose extended alias:
[1] 01620.mpls
Select number (Enter to cancel): 1
Taken from my script run, see how confusing the Theatrical selection is. I had to tweak the selection criteria to narrow it down to the picks, 00800 or 00037.mpls,
Script picks a clear winner in 01620.mpls for Extended Cut, I then select to auto-open the Playlist in Finder on mac os and drag it into Tsmuxer GUI or MKVToolnix or find it in Makemkv GUI and Remux
Updated script output for reference
CUT MPLS DURATION CH IT
THEATRICAL 00075 2:23:05 16 18
EXTENDED 01620 2:37:37 17 22
EXTENDED_ALT 00037 2:35:02 17 21
ALIAS 00039 2:35:02 17 21
ALIAS 00290 2:35:02 17 21
ALIAS 00309 2:35:02 17 21
ALIAS 00350 2:35:02 17 21
ALIAS 00424 2:35:02 17 21
ALIAS 00440 2:35:02 17 21
ALIAS 00468 2:35:02 17 21
ALIAS 00482 2:35:02 17 21
ALIAS 00521 2:35:02 17 21
ALIAS 00562 2:35:02 17 21
ALIAS 00677 2:35:02 17 21
ALIAS 00693 2:35:02 17 21
ALIAS 00735 2:35:02 17 21
ALIAS 00797 2:35:02 17 21
ALIAS 00800 2:35:02 17 21
ALIAS 00865 2:35:02 17 21
ALIAS 00934 2:35:02 17 21
ALIAS 01121 2:35:02 17 21
ALIAS 01122 2:35:02 17 21
ALIAS 01250 2:35:02 17 21
ALIAS 01292 2:35:02 17 21
ALIAS 01306 2:35:02 17 21
ALIAS 01388 2:35:02 17 21
ALIAS 01416 2:35:02 17 21
ALIAS 01419 2:35:02 17 21
ALIAS 01450 2:35:02 17 21
ALIAS 01458 2:35:02 17 21
ALIAS 01483 2:35:02 17 21
ALIAS 01492 2:35:02 17 21
ALIAS 01577 2:35:02 17 21
ALIAS 01633 2:35:02 17 21
ALIAS 01670 2:35:02 17 21
ALIAS 01724 2:35:02 17 21
ALIAS 01736 2:35:02 17 21
ALIAS 00077 2:23:05 16 18
ALIAS 00081 2:23:05 16 18
ALIAS 00135 2:23:05 16 18
ALIAS 00194 2:23:05 16 18
ALIAS 00201 2:23:05 16 18
ALIAS 00210 2:23:05 16 18
ALIAS 00384 2:23:05 16 18
ALIAS 00412 2:23:05 16 18
ALIAS 00435 2:23:05 16 18
ALIAS 00455 2:23:05 16 18
ALIAS 00466 2:23:05 16 18
ALIAS 00472 2:23:05 16 18
ALIAS 00525 2:23:05 16 18
ALIAS 00754 2:23:05 16 18
ALIAS 00780 2:23:05 16 18
ALIAS 00790 2:23:05 16 18
ALIAS 00794 2:23:05 16 18
ALIAS 00814 2:23:05 16 18
ALIAS 00869 2:23:05 16 18
ALIAS 00891 2:23:05 16 18
ALIAS 00950 2:23:05 16 18
ALIAS 00994 2:23:05 16 18
ALIAS 01051 2:23:05 16 18
ALIAS 01054 2:23:05 16 18
ALIAS 01159 2:23:05 16 18
ALIAS 01214 2:23:05 16 18
ALIAS 01301 2:23:05 16 18
ALIAS 01334 2:23:05 16 18
ALIAS 01337 2:23:05 16 18
ALIAS 01474 2:23:05 16 18
ALIAS 01485 2:23:05 16 18
ALIAS 01524 2:23:05 16 18
ALIAS 01573 2:23:05 16 18
ALIAS 01606 2:23:05 16 18
ALIAS 01735 2:23:05 16 18
ALIAS 01869 2:23:05 16 18
ALIAS 00245 1:17:09 16 9
ALIAS 00001 1:07:10 7 6
ALIAS 00106 0:50:15 9 8
ALIAS 00002 0:31:52 5 5480
ALIAS 00008 0:19:15 6 5
ALIAS 00020 0:02:18 7 6
ALIAS 00000 0:00:00 2 0
ALIAS 00003 0:00:00 2 0
ALIAS 00004 0:00:00 2 0
ALIAS 00005 0:00:00 2 0
ALIAS 00006 0:00:00 2 0
ALIAS 00007 0:00:00 2 0
ALIAS 00009 0:00:00 2 0
ALIAS 00010 0:00:00 2 0
ALIAS 00011 0:00:00 2 0
ALIAS 00012 0:00:00 2 0
ALIAS 00013 0:00:00 2 0
ALIAS 00014 0:00:00 2 0
ALIAS 00015 0:00:00 2 0
ALIAS 00016 0:00:00 2 0
ALIAS 00017 0:00:00 2 0
ALIAS 00018 0:00:00 2 0
ALIAS 00019 0:00:00 2 0
ALIAS 00021 0:00:00 2 0
ALIAS 00022 0:00:00 2 0
ALIAS 00023 0:00:00 2 0
ALIAS 00024 0:00:00 2 0
ALIAS 00025 0:00:00 2 0
ALIAS 00026 0:00:00 2 0
ALIAS 00027 0:00:00 48 0
ALIAS 00028 0:00:00 9 0
ALIAS 00102 0:00:00 2 0
ALIAS 00103 0:00:00 2 0
ALIAS 00104 0:00:00 2 0
ALIAS 00105 0:00:00 2 0
ALIAS 00646 0:00:00 17 0
ALIAS 01040 0:00:00 17 0
ALIAS 01434 0:00:00 16 0
ALIAS 01679 0:00:00 17 0
ALIAS 01789 0:00:00 17 0
ALIAS 01997 0:00:00 1 0
ALIAS 01998 0:00:00 1 0
ALIAS 01999 0:00:00 1 0
Cluster overview (family → members, item_count_hint, winner)
dur:0157 → members= 1 items≈ 22 winner=01620
dur:0155 → members= 35 items≈ 21 winner=00037
dur:0143 → members= 37 items≈ 18 winner=00075
dur:0077 → members= 1 items≈ 9 winner=00245
dur:0067 → members= 1 items≈ 6 winner=00001
dur:0050 → members= 1 items≈ 8 winner=00106
dur:0019 → members= 1 items≈ 5 winner=00008
dur:0002 → members= 1 items≈ 6 winner=00020
items:000 → members= 37 items≈ 0 winner=00027
[13:51:14] [GUI] Opening 01620.mpls in tsMuxer GUI.
