PIONEER BDR-209 change the Firmware ?
sounds
Re: PIONEER BDR-209 change the Firmware ?
Post by sounds »
just to follow up on this, after contacting Billy via email and paying the $25, I received a link to a folder with some files. Downloaded that and ran the executable on a Windows machine, firmware update completed first time with no issues. Power cycled the drive (it's in a USB enclosure) and hey presto, the drive is now able to recognise (and read!) 4k discs. Read time was about 50 minutes (appears to top out at around 4X), roughly similar to the ASUS drive I had previously. But for DVDs it's definitely faster, possibly normal BluRays too. For reference purposes, the drive now identifies as:
Manufacturer: PIONEER
Product: BD-RW BDR-211M
Revision: 1.53
Serial number: SGDL0****6WL
Firmware date: 2020-08-03
Bus encryption flags: 13
Highest AACS version: 72
Drive platform: RS8801
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID60
so yes, for me this is a recommended solution until the newer makemkv solution is out. Even then, this may still be required to rip 4k discs - as prior to the firmware update the drive would attempt to read 4k discs a few times ... then spit the disc out. Now it reads them fine on the first attempt.
xwmkf
Post by xwmkf »
Just picked up this drive:
OS device name: /dev/rdisk20
Product: BD-RW BDR-209
Revision: 1.34
Firmware date: 2016-04-25
Highest AACS version: 81
Drive platform: RS8600
Firmware version: 1.34/ID81
If I understand correctly, LibreDrive doesn't mean UHD support -- but this drive is one that can be flashed to read UHD discs?
xwmkf wrote: Sat Nov 01, 2025 10:15 pm Just picked up this drive:
Revision: 1.34
PM sent.
Outtheredude
Post by Outtheredude »
Hello, I have the following Pioneer BDR-209EBK drives I would like to change up the firmware to handle UHDs with:
OS device name: F:
Product: BD-RW BDR-209M
Revision: 1.54
Serial number: OJDL036860WL
Firmware date: 2020-07-21
Firmware version: 1.54/ID60
And:
OS device name: G:
Revision: 1.54
Serial number: OJDL037103WL
Would appreciate help with this matter please, thanks! :-)
xwmkf
Post by xwmkf »
Coopervid wrote: Mon Nov 03, 2025 5:06 pm
Revision: 1.34
PM sent.
Got the files and flashed, worked like a charm, thank you so much! Donation sent. Drive now reports as:
Product: BD-RW BDR-S11
Revision: 1.53
Drive platform: RS8800
Firmware version: 1.53/ID43
Outtheredude wrote: Mon Nov 03, 2025 7:32 pm Hello, I have the following Pioneer BDR-209EBK drives I would like to change up the firmware to handle UHDs with:
OS device name: F:
Revision: 1.54
And:
OS device name: G:
Revision: 1.54
PM sent.
sonyepson
Post by sonyepson »
Could you please send me the UHD-friendly firmware for the following drive? Would be highly appreciated :D .
Revision: 1.10
Serial number:
Firmware date: 2013-09-10
Highest AACS version: 76
Firmware version: 1.10/ID60
sonyepson wrote: Thu Nov 06, 2025 10:45 pm Could you please send me the UHD-friendly firmware for the following drive? Would be highly appreciated :D .
Revision: 1.10
Serial number:
PM sent.
sonyepson
Post by sonyepson »
Flashed, worked like a charm, thank you so much! Donation sent.
irishguy74
Post by irishguy74 »
hi.
is there a firmware available to allow ripping of 4k blurays on the following drive (BDR 209D)?
OS device name: I:
Product: BD-RW BDR-209D
Revision: 1.51
Serial number: NLDL054876WL
Firmware date: 2018-05-08
Highest AACS version: 62
Firmware version: 1.51/ID61
thanks a mill
irishguy74 wrote: Mon Nov 24, 2025 10:00 pm hi.
OS device name: I:
Revision: 1.51
thanks a mill
PM sent.
irishguy74
hi Coopervid,
that works fine. thank you. donation sent .
bobikjacek
Post by bobikjacek »
Please help me with my drive
Informacje o napędzie
Nazwa systemowa: D:
Producent: PIONEER
Produkt: BD-RW BDR-209D
Wersja: 1.51
Numer seryjny:
Data firmware: 2018-05-08
Flagi szyfrowania bus: 13
Thank you
bobikjacek wrote: Mon Dec 01, 2025 3:19 pm Please help me with my drive
Nazwa systemowa: D:
Producent: PIONEER
Wersja: 1.51
Numer seryjny:
Thank you
PM sent.
locksbox
Post by locksbox »
Hi there,
Is it possible to firmware fix my Pioneer BD-RW BDR-S09 sadly I have the last firmware 1.55, I suspect it won't be able to.
Many thanks.
The details are below:
Product: BD-RW BDR-S09
Revision: 1.55
Serial number: [removed]
Firmware date: 2023-02-16
Firmware version: 1.55/ID43
