Desktop to Slim drive nightmare, need help
halstedmichael
Post by halstedmichael »
The title states, I'm pretty sure I chose the wrong Libre flash for my drive. I have a Buffalo BRXL-16U3, And instead of searching forums I chose to take a crack at SDFtool flasher. And I'm now sitting here with what I'm pretty sure is a bricked drive. My dumb *** thought since the drive is external that it's clearly a "slim" drive and not a desktop drive. But it appears not.
I dumbly chose LG BU40N without searching and saw that another user chose LG 5.25 and his is working fine. My computer recognizes the drive, LibreDrive is enabled now and all the right things look patched. However, my eject button doesn't work, MAKEmkv and my PC cannot eject the disc. And when I manually open it and place a disk in, it no longer reads.
Current readings are this:
Product (now says): BD-RE BU40N
Revision: 1.03
LibreDrive:
Platform: MT1959
ETC ETC
And when I "Read" the firmware to dump the files and attempt to "write" the correct one, I get a error code 0xff05c103.
Is there a possible solution? And if so, will I retain the products ability to use the eject button again? Not a deal breaker as MAKEmkv just ejects for you when you tell it to. But am I boned here? Any and all help would greatly be appreciated.
Re: Desktop to Slim drive nightmare, need help
halstedmichael wrote: Mon Nov 03, 2025 5:57 pm The title states, I'm pretty sure I chose the wrong Libre flash for my drive. I have a Buffalo BRXL-16U3, And instead of searching forums I chose to take a crack at SDFtool flasher. And I'm now sitting here with what I'm pretty sure is a bricked drive. My dumb *** thought since the drive is external that it's clearly a "slim" drive and not a desktop drive. But it appears not.
Revision: 1.03
LibreDrive:
Platform: MT1959
ETC ETC
Boy - you have afull size drive and haven't read the warning!
What you can try is the recovery function of SDFTool. Use recovery. Pick the current firmware that you flashed and then WH16NS60 1.02 to flash. Watch the video.
viewtopic.php?f=16&t=22896&hilit=SDFTool
halstedmichael
Coopervid wrote: Mon Nov 03, 2025 6:57 pm
Revision: 1.03
LibreDrive:
Platform: MT1959
ETC ETC
Yeah, that was a big mistake on my part. Lesson learned I suppose. I'll try that method today. And which video are you referencing? The visual video embedded on the post or a link to a video? Thanks again for the recommendation.
The visual aid. You need to pick first what is currently flashed to the drive and then in the second box WH16NS60 1.02 which can be found in the All you need firmware package.
halstedmichael
Coopervid wrote: Tue Nov 04, 2025 1:15 pm The visual aid. You need to pick first what is currently flashed to the drive and then in the second box WH16NS60 1.02 which can be found in the All you need firmware package.
Okay, awesome. It allowed me the flash and finish that. Now I just need you to get my over the mountain :lol: Eject button works again, it allows me to use software or the physical button. But now the drive is having a hard time reading discs, or not at all I should say. And at the beginning of running MakeMKV, it says "Automatic SDF downloading is disabled or failed." Not sure why or how to adjust that. And this is the current read out for the drive in the program.
OS device name: E:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number:*************
Highest AACS version: 82
Firmware version: 1.02
Any additional advice is always welcome. Thank you again for helping me this far.
DavoBR
Post by DavoBR »
Wash your BDs and UHDs with liquid soap and warm water. Dry with a paper towel. Then wipe them with a microfiber cloth as used for cleaning glasses.
halstedmichael
So it isn't an issue with the discs themselves. I've tried different ones. I'm getting the same "Downloading latest SDF to C:\Users\halst.DESKTOP-OA8A8RA/.MakeMKV ..." even after the fix. So my first question is, I've seen others manually download it. But when I download the SDF file, I can't move it from my downloads to the data directory for MakeMKV. Not sure if that's an issue. But I'm also stuck where my drive no longer reads discs now after my flash fix.
OS device name: E:
Revision: 1.02
Serial number: SIK9NH989213
halstedmichael
So I was able to finally get the SDF file moved to the data directory for MAKEmkv. However, though it no longer says "downloading", my drive is still unable to read any disc. Whether DVD/BLU-RAY/ or 4K. I'm wondering if there is/was an additional step during the flash or process I may have missed or possibly messed up? Has anyone else had an issue of their drive no longer reading discs after a flash? Thanks again.
