Install MakeMKV on Fedora
Falco
Re: Install MakeMKV on Fedora
#31 Post by Falco » Mon Aug 19, 2024 5:19 pm
Hi Stefan1
Thx a lot for your feedback. :D
This script is dedicated to deployment.
But sure, you can use it to "update automatically" by reinstalling like in original deployment, I mean download, compile and install.
The role makemkv first test is to check if /usr/bin/makemkv exist.
It means you only need to rename /usr/bin/makemkv to reinstall from scratch this software.
File: ansible-post-install-my-fedora/roles/makemkv/tasks/main.yml ( task in line 13 ).
Regarding Sudo, yeah Download, and Compile don't need root privileges compare to Install.
But keep in mind this script is multi roles and in a full deployment (using all or some roles) that make no sense to interrupt all times to ask validations or passwords.
Imagine using this script on 200 computers in one shot, you could do it.
This is the ansible philosphy, start your playbook and when it is done everything are in the state that you decided.
I hope my explanation is understanding.
Falco
#32 Post by Falco » Fri Nov 08, 2024 6:25 pm
Hi Fedora users,
The script is validated yesterday on my laptop after a fresh new system installation from scratch over Fedora 41
:D
AngryHandyman
#33 Post by AngryHandyman » Tue Nov 19, 2024 2:02 am
Thanks for the work on this, your script and clarified instructions worked great on my Fedora 41 instance.
Cheers.
rolle
#34 Post by rolle » Tue Nov 19, 2024 8:37 am
- Rename this binary /usr/bin/makemkv
- Modify the myvars.yml file
- And Replay only the makemkv role.
Example:
sudo mv /usr/bin/makemkv /usr/bin/makemkv-OLD
Change myvars.yml content, from 1.17.3 to 1.17.4
sudo ansible-playbook myFedora.yml -t onlymkmkv
after that calculate and compare the size of both files if it exceed than the old one, the process is right.
Falco
#35 Post by Falco » Sun Nov 24, 2024 7:11 pm
I'm really happy this ansible script is helpful. :P
I edited the Readme files (the general Readme and the task's Readme), I hope it explains better why to update the myvars.yml file.
darthmongo
#36 Post by darthmongo » Wed Mar 05, 2025 5:15 pm
Thank you so much for making your script available! I've been struggling to translate the Ubuntu instructions to compile MakeMKV to Fedora and have been running into all sorts of walls. This makes it so much easier. I did have an issue where it failed to launch after upgrading to Fedora 41, but deleting the app and recompiling fixed that problem (I don't recall the specific error now).
Falco
#37 Post by Falco » Wed Mar 05, 2025 6:17 pm
My older son, at his home weeks ago, faced same issue like you after upgraded Fedora 40 to 41.
Because I was driving, I just told to him to do like you did, I mean remove the previous binary and compile from my script.
(Exactly the same process than to upgrade Makemkv).
It was late and it was successful and I confess I did not insist to know what was the real issue.
Really happy it was helpful for you too. :P
Thanks a lot for your feedback Darthmongo
Falco
#38 Post by Falco » Mon Nov 03, 2025 4:42 pm
Hello everyone,
Tested last weekend on a brand new Fedora 43 installation.
Everything works perfectly.
BR
darthmongo
#39 Post by darthmongo » Wed Nov 05, 2025 3:17 am
Still loving your script, and I want to use it for my own configs now that I've completely switched off Windows and am running Fedora 100% on my system now, but I ran into a problem where Handbrake stopped working after updating to Fedora 43. Tried rerunning the compiler script using the handbrake tag, but it just reports ok=1. What's the best way to do a reinstall? I've done this before with MakeMKV where I deleted the config files and program files and then recompiled, but I can't find the Handbrake binary anywhere to remove it.
--darthmongo
darthmongo
#40 Post by darthmongo » Wed Nov 05, 2025 3:37 pm
--darthmongo
After some research into how your Ansible script works, I found the Handbrake installation configs and that took me to the Handbrake developer page where, after doing some digging, I found how to force a recompile/install of the software, which worked. Just thought I'd leave some breadcrumbs here in case others had a similar issue.
Falco
#41 Post by Falco » Wed Nov 05, 2025 7:13 pm
Hi Darthmongo
Easy to do
You probably saw skipped status (in blue). :mrgreen:
As you can see in roles/handbrake/tasks/main.yaml
There is a part dedicated to test if Handbrake is already installed
If you rename this tested file it will be good
mv /usr/local/bin/HandBrakeCLI /usr/local/bin/HandBrakeCLI_Old
And now replay my script :
sudo ansible-playbook myFedora.yml -t handbk
or
sudo ansible-playbook myFedora.yml -t onlyhandbk [ if required packages are already installed ]
Normally the script will do the job llike for a first installation.
This is the same process if you want to update because you think there is some new release on Handbrake Git project .
Same process for MakeMKV !!!
I already provided details in this topic. :D
Look at : roles/makemkv/README.md
Yeah I will do the same inside roles/handbrake/README.md :oops:
All can be managed through my script, if you rename the test binary presence.
Let me know if it help please
Falco
#42 Post by Falco » Sat Nov 08, 2025 12:43 pm
Hi Guys
Like for this readme file roles/makemkv/README.md
I updated the HandBrake readme file too. :D
Just look at roles/handbrake/README.md
BR
roberte1342
#43 Post by roberte1342 » Sat Nov 08, 2025 9:29 pm
Thank you for putting this together. I'll be attempting to install this on my FC42 box in the next few days.
Falco
#44 Post by Falco » Mon Nov 10, 2025 6:45 pm
Ok you will let me know Roberte
Otherwise upgrade and recompile is now managed. :mrgreen:
No need to delete manually it is managed by my script now.
Explained there:
Thanks for the challenge, it helps me to progress.
BR
roberte1342
#45 Post by roberte1342 » Thu Nov 13, 2025 12:36 am
Worked great! There was only one hiccup in my install, I was missing "community.general" the following command fixed it for me:
sudo ansible-galaxy collection install community.general
Thanks again for sharing this.
