Multiple instances
Multiple instances
I have two drives I want to be able to use simultaneously to back up series box sets.
Opening two instances of MakeMKV mostly works, until it doesn't.
The biggest problem is more of an annoyance. When one disc finishes and you eject it, the drive selection automatically flips to the other (busy) drive. If you correct it at this point, it flips back again. You can only do it and have it stay after inserting another disc.
This also seems to occasionally cause one of the running instances to get confused about which disc it's reading and error out partway.
Likely the easiest fix is to have an option to disable drive auto selection.
Re: Multiple instances
Turn on 'Ask for single drive mode' on the IO tab in MakeMKV's preferences.
AH, thanks. I saw that but didn't think it was appropriate because I don't have a single drive.
... And it still does it.
After turning on that setting, when you start MakeMKV it should ask you which drive you want to lock that instance of MakeMKV to. Pick one of your drives, don't pick 'All drives'.
To use a second drive, make a new instance of MakeMKV. Lock that instance to a different drive by picking a different drive from the drop down when that instance starts.
Did all that. The Windows version doesn't seem to have a "New instance" in the menu.
The second instance seems to work properly. The first instance (which asked which drive), flips to the second drive after ejecting the disc it just finished in the first drive.
Additional info:
I closed and restarted the first instance (while the second was running). Again it asked which drive and I chose the first drive. Loaded a disc and it detected it. Clicked the Open DVD disc button. Got the following log:
Clicked the Open DVD button again, and it worked:
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS40 1.03 (redacted)' at offset '8131198976'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS40 1.03 (redacted)' at offset '7959037952'
Cells 1-2 were removed from title start
Title #1 has length of 2335 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #2 was added (11 cell(s), 0:40:16)
Cells 1-1 were removed from title start
Cells 13-13 were removed from title end
Title #3 has length of 2257 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Cells 13-14 were removed from title end
Title #4 (0:45:07) was skipped due to navigation error
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '0'
... (repeats a couple dozen times)
Failed to open discCode: Select all
Title #1 was added (13 cell(s), 0:44:58)
Title #2 was added (13 cell(s), 0:44:59)
Title #3 was added (13 cell(s), 0:44:57)
Title #4 was added (14 cell(s), 0:45:00)
Operation successfully completed-
gkar_of_narn
I know this won't help, but the last time I had a computer that could multi-task multiple drives simultaneously was an Amiga 500. Separate processors for just about everything in it. The CPU just sent the commands and the dedicated processors would take over. But that was a long time ago, barely remember that stuff.
I occasionally use two and sometimes three drives at a time and they all operate independently. I've seen Billycar11 post pictures of a dozen drives in use at a time on his Windows machine while testing drives being preparing for sale. I've seen people on the forum get frustrated that the limit seems to be 16 drives at a time.
In my case, all my drives are LibreDrive enabled drives. I have no idea if that matters.
I spent a lot of hours in front of an Amiga 500 and eventually an Amiga 2000 with a Video Toaster when I was growing up.
gkar_of_narn
I loved the Amiga. I think the Babylon 5 special effects were done on the Amiga 2000.
I think they did it all in Lightwave 3D (https://en.wikipedia.org/wiki/LightWave_3D). Wikipedia says Lightwave came out for Mac and Windows in 1994 and was discontinued on Amiga in 1995. Babylon 5 started in February 1993.
https://en.wikipedia.org/wiki/Babylon_5#VisualsWikipedia wrote:The visual effects were achieved using Amiga-based Video Toasters at first, and later Pentium, Macintosh, and Alpha-based systems using LightWave 3D.
DMA (Direct Memory Access) does basically the same thing. The controller on each drive handles its own operations directly to/from memory.gkar_of_narn wrote: Mon Nov 03, 2025 1:01 pm I know this won't help, but the last time I had a computer that could multi-task multiple drives simultaneously was an Amiga 500. Separate processors for just about everything in it. The CPU just sent the commands and the dedicated processors would take over. But that was a long time ago, barely remember that stuff.
gkar_of_narn
Thanks, didn't know that.
