Help getting blu-ray menus working
the_sunflower
Post by the_sunflower »
I've been working on this problem for a few days so far and I've made no progress.
OS is manjaro linux (arch based)
VLC media player 3.0.21 Vetinari (revision 3.0.21-0-gdd8bfdbabe8)
Makemkv 1.18.2 (compiled from source because linux; installed to /usr/bin)
libmmbd is in /usr/lib natively and is not a symlink
Java versions installed:
jre-openjdk 25.u36-1
jre17-openjdk 17.0.16.u8-1 (default; confirmed via archlinux-java status)
java -version
openjdk version "17.0.16" 2025-07-15
I live in Region A, VLC is set to region A, and the media is region A.
I have the following packages/libraries installed: libbluray libaacs aribb24 extra/vlc-plugin-aribb24 extra/vlc-plugin-bluray
When I try to open a blu-ray (either from a spinning optical disc or a backup made via mkv) I get the following loop in VLC's log:
libbluray: Initializing overlay
main debug: creating demux: access='' demux='ts' location='' file='(null)'
main debug: looking for demux module matching "ts": 47 candidates
main debug: no demux modules matched
main debug: attempt to destroy nonexistent variable "next-chapter"
main debug: attempt to destroy nonexistent variable "prev-chapter"
main debug: ES_OUT_RESET_PCR called
That gets printed a few hundred times per second in a constant loop. Nothing ever happens. I can provide a full vlc_log if that would help. Also, despite me (trying to) follow the guides on how to get the Integration with makemkv setup, the Integration list in makemkv remains empty.
16442496
Re: Help getting blu-ray menus working
Post by 16442496 »
Does installing libbluray-bdj help?
Debian
MakeMKV 1.17.6 (Registered)
DVD to MKV only.
the_sunflower
sudo pacman -S libbluray-bdj
error: target not found: libbluray-bdj
I already tried asking chatgpt. It hallucinates that package existing.
georgesgiralt
Post by georgesgiralt »
On my Ubuntu (Noble) :
apt search libbluray*
En train de trier... Fait
Recherche en texte intégral... Fait
libbluray-bdj/noble,noble,now 1:1.3.4-1build1 all  [installé]
  bibliothèque Java de gestion des disques Blu-ray –⋅bibliothèque BD-J
standforme
Post by standforme »
georgesgiralt wrote:
Mon Nov 03, 2025 1:57 pm
That's the ticket. I also normally run an Arch-based distro, like OP (Garuda, in my case), and have been batting zero, even getting and building libbluray-bdj myself. I just tried an Ubuntu 24.04 live USB stick, installed VLC and libbluray-bdj, opened the disc folder (MakeMKV disc backup, the folder containing the BDMV folder) with VLC, and got intros and menus.
hanshotfirst1138
Post by hanshotfirst1138 »
I'm having similar issues. When I play through VLC, it says that Java isn't installed even though it is, and it won't let me us Blu-ray menus. This is significantly better than before when I couldn't get Make MVK and VLC to integrate at, at which I have finally been successful, but I still need the menu to access special features and other things. Any ideas?
librelibre
Post by librelibre »
Had to try a lot of different things to get it working, so I'm not quite sure the order i which I tried them, and don't recall everything I did.
At one point needed to reinstall makemkv (v 1.18.2). Originally built it with checkinstall I think so to have a deb file that I could install and remove. And be able to purge settings.
Also have 1.17.7 installed in a different directory and bin folders. So I dunno if that caused any conflicts. I didn't create a deb for that. Forgot what I did to install 1.17.7.
Things I tried:
Made sure VLC was set to the correct region
(Re)installed Java 17 and libbluray-bdj
`apt install libbluray-bdj openjdk-17-jre`
set the path
`export JAVA_HOME=/usr/lib/jvm/java-17-openjdk-amd64`
For some reason though that's no longer set. And it reports java 21 as my current version. So I guess next time I reboot I'll see if everything is working later...
I did create a symlink at one point. It took me a while to figure out that it can show up in different directories and VLC uses the one in the x86_64-linux-gnu directory (at least on ubuntu/linux mint). Deleted the other copy in /usr/lib.
Helps to search for libmmbd to see where it might exist
`find /usr/lib -name 'libmmbd.so.0'`
Created symlinks, but for some reason only the one to libaacs exists currently. At one point I removed libaacs0, which which of the guides I read had suggested to install.
cd /usr/lib//x86_64-linux-gnu
sudo ln -s libmmbd.so.0 libaacs.so.0
sudo ln -s libmmbd.so.0 libbdplus.so.0
sudo ldconfig
The Libdbplus has since disappeared.
Rebooted after making changes.
Before running VLC opened makemkv first, left it open and then started VLC.
dynasty8122
Post by dynasty8122 »
On the very odd chance a fellow ubuntu noob sees the 'you need java' error/notice in the MakeMKV log and would like it to go away--this here (mined from @librelibre's post) seems to have worked for me:
sudo apt install libbluray-bdj openjdk-17-jre
This is running Ubuntu 24.04.4 LTS, MakeMKV v1.18.3 linux(x64-release), and ripping LOTR Fellowship extended edition. Disc/Part 1 gave the error (tho I was still able to rip). After that apt install command, disc/part 2 gave note
Using Java runtime from /usr/lib/jvm/java-21-openjdk-amd64/bin/java
Many thanks @librelibre for sharing what you did to get things working.
